Home > Technical > Blue smoke
erfec10
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Blue smoke
Big Cry
Can drive a few days and all ok.
Next day I may push the engine just to give it a wee clean out, then it happens, a large puff of blue smoke,
Can't see behind me with mirror, no noise, no change in power just smoke.
This has only happened 4 or 5 times, had a look over the engine, removed the rubber hose from the intercooler and quite a bit of oil in the hose.
2010 year 60 reg...69k on clock full service history.
Post #495088 Tue May 03 2016 9:09pm
Rich
Had similar on my 2010 MY. It was a known problem - a turbo drain hose I think. I think it is the second turbo that cuts in about 2800 rpm. This one doesn't get used so much so if the drain hose is blocked or collapsed there is a build up of oil in the turbo which is burnt when you do give it some wellie. My main dealer dealt with it when it was serviced last November.
This was done at Land Rover's expense.
Post #495090 Tue May 03 2016 9:37pm
erfec10
Thanks Rick, will contact them to get it repaired, cheers
Post #495112 Wed May 04 2016 9:55am
Disco_Mikey
Known issue relating to the oil return pipe from the RH turbo
New pipe fitted along with a blanking plate Thumbs Up
Downside is, as you are out of manufacturers warranty, it will likely not be covered, and you will have to pay yourself
Post #495114 Wed May 04 2016 10:09am
Rich
Although mine was still in an "approved used" warranty period, my dealer told me the charge for fixing the turbo pipe was not against the warranty but against Landrover directly as it was a known issue. Try to get them to pay!
Post #495134 Wed May 04 2016 4:18pm
Disco_Mikey
If it is a recall, it's paid for by JLR
This issue is covered by a TSB to aid diagnostics, and only covered under the manufacturers warranty
Generally, aftermarket warranty companies do not cover "known issues" unless it is the LR Approved Warranty
I have heard of it being covered under goodwill, but in general, it is a chargeable repair Thumbs Up
Post #495138 Wed May 04 2016 6:02pm
erfec10
Disco Mike.
Can you do this repair at my house disco Mike
Get back with info and I could leave the keys Mike.
Post #495143 Wed May 04 2016 8:55pm
Disco_Mikey
I can, but I'm off this week and next following a new baby, and working in the new workshop the following week in case the wife needs me. I'll be back to normal, and down your way on the 23rd though Thumbs Up
Post #495144 Wed May 04 2016 9:10pm
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Had exactly the same issue which warranty company rejected today. Turbo drain pipe. Dealer quoted £377 but Disco Mikey suggested that was toppy.
I might wait for you to come to Aberdeen again or book mine in with you DM at ur workshop.
Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #495146 Wed May 04 2016 9:27pm
Disco_Mikey
Not a problem sir Thumbs Up
Post #495153 Thu May 05 2016 5:14am
erfec10
Will get back to you, sure i am away to Harrogate then.
Post #495161 Thu May 05 2016 10:55am
Mr Rusty
I have PM'd u Mike Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
Post #495391 Sun May 08 2016 8:17am
Mr Rusty
Erfec10
LR also told me today that they would cover the cost of the drain pipe work as per TSB.
My warranty company wouldn't.
Post #495807 Thu May 12 2016 9:04pm
Disco_Mikey
Good news Thumbs Up
Post #495808 Thu May 12 2016 9:33pm
Mr Rusty
Indeed Mike. Happy days! Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
Post #495809 Thu May 12 2016 9:35pm
