Home > General > Range Rover Sport SDV6 or 5 litre or 4.2 litre S/C V8 Advice |
With such short journies I would say go for the V8 petrols. Diesels prefer longer steady RPM runs without lots of gearchnages/ rev changes to achieve better economy. Also if you go for any diesel RRS built after 2013 then you get a DPF that has to be able to regenerate and that is achieved over a twenty minute stint at higher than normal rpm which is a speed over about 45mph....... not a lot of use in the Channel Islands. 4.2V8's will be getting a bit elderly now so a 5ltr V8 form around facelift time for RRS1 (2010MY to 2013MY) if you don't want a new car or an L494 5.0V8 Autobiograhy if you don't mind spending 87000 on a new car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Feb 19 2016 9:13pm |
mintyuk Member Since: 03 Jan 2016 Location: Essex Posts: 37 |
Totally agree - DPF filters tend to "clog up" with lots of short journeys at lower speeds.
Fri Feb 19 2016 9:26pm |
Range_Rover73 Member Since: 04 Jan 2016 Location: United Kingdom Posts: 18 |
Thank you both for the great advice, the 5 litre supercharged was my preferred option, so you have made my day 👍🏻
Fri Feb 19 2016 9:34pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Petrol is definitely the best option, but absolutely wasted! Visiting from DISCO3.CO.UK
Sat Feb 20 2016 9:53am |
Sat Feb 20 2016 9:58am |
4X4BYFAR Member Since: 14 Feb 2016 Location: West Midlands Posts: 57 |
If you're spending over 20k you should look at a 6.0 Bentley continental GT. I've had one before... Ducking cracking car, I mean amazing. Cheap now aswell, I've seen them for 17'500 |
Sat Feb 20 2016 7:45pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Sun Feb 21 2016 3:09am |
Very helpful 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Sun Feb 21 2016 9:28am |
Is there any major benefits with the 2012 RRS compared to the 2009 - 2011 Supercharged or is it just the powered tailgate? |
Mon Apr 25 2016 7:20pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Don't know about the changes in spec but would go for as new as pos and lowest mileage as long as it's been serviced unless you are going for something special.. 2008 G4 RRSport TDV8 current
Mon Apr 25 2016 10:02pm |
What would you consider as low mileage? Less than 50k miles or less than 80k miles? |
Tue Apr 26 2016 5:40am |
Rule of thumb would be average annual mileage for UK is between 10.000 and 12000 miles, anything significantly below or above that would count as below average or above average. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Apr 26 2016 6:48am |
Thank you |
Tue Apr 26 2016 8:16am |
