Home > General > Range Rover Sport SDV6 or 5 litre or 4.2 litre S/C V8 Advice
Range_Rover73
2011 Range Rover Sport Supercharged Autobiography Sumatra Black
Hello,
I'm new to this forum and currently looking to purchase a RRS. I live in the Channel Islands and the majority of journeys only take between 15 and 45 minutes with a maximum speed of 35mph. For short duration journeys like this would you recommend the petrol or diesel?
I've been told in the past that Diesel engines can be troublesome if only used on short journeys is this correct?
Also which version is generally lower maintenance?
My options I'm considering at the moment are:-
4.2 S/C V8
5.0 S/C V8
3.0 SDV6
Which are the best years?
Thanks in advance 😊👍🏻
Post #488116 Fri Feb 19 2016 5:34pm
Tim in Scotland
With such short journies I would say go for the V8 petrols. Diesels prefer longer steady RPM runs without lots of gearchnages/ rev changes to achieve better economy. Also if you go for any diesel RRS built after 2013 then you get a DPF that has to be able to regenerate and that is achieved over a twenty minute stint at higher than normal rpm which is a speed over about 45mph....... not a lot of use in the Channel Islands. 4.2V8's will be getting a bit elderly now so a 5ltr V8 form around facelift time for RRS1 (2010MY to 2013MY) if you don't want a new car or an L494 5.0V8 Autobiograhy if you don't mind spending 87000 on a new car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #488155 Fri Feb 19 2016 9:13pm
mintyuk
United Kingdom 2007 Range Rover Sport Supercharged HSE Stornoway Grey
Totally agree - DPF filters tend to "clog up" with lots of short journeys at lower speeds.
The shorter/slower trips also mean that the financial benefits you would get from the better MPG obtained from diesel, will not be quite so evident.
This could also been seen as good news though, as you can now just see which engine gives you the biggest grin factor on the test drives ......... and to be honest, all else being equal, isn't that a really important decision maker?? It was for me, and most of my trips are short distances too.
Whatever you decide, I absolutely sure you'll love it!! Very Happy Rangie History ....
2007 Range Rover Sport 4.2 s/c HSE
2000 Range Rover P38 4.6v8 Vogue
1997 Range Rover P38 4.6v8 HSE
Post #488160 Fri Feb 19 2016 9:26pm
Range_Rover73
Thank you both for the great advice, the 5 litre supercharged was my preferred option, so you have made my day 👍🏻
It was definitely the one that put the biggest smile on my face 😊
Unfortunately I can't justify a new one at the moment, so looking at a facelift 2010 to 2013 version.
Is there any major benefits with the 2012 or is it just the powered tailgate?
Post #488164 Fri Feb 19 2016 9:34pm
Lost for Words
Petrol is definitely the best option, but absolutely wasted! Laughing Thumbs Up Visiting from DISCO3.CO.UK
Post #488223 Sat Feb 20 2016 9:53am
Range_Rover73
Rolling with laughter Rolling with laughter Thumbs Up
Might give it a treat and take it to mainland for a blast occasionally 👍🏻
Post #488225 Sat Feb 20 2016 9:58am
4X4BYFAR
If you're spending over 20k you should look at a 6.0 Bentley continental GT. I've had one before... Ducking cracking car, I mean amazing. Cheap now aswell, I've seen them for 17'500
Post #488287 Sat Feb 20 2016 7:45pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Shocked
Post #488340 Sun Feb 21 2016 3:09am
Buckster
Very helpful Rolling Eyes 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #488362 Sun Feb 21 2016 9:28am
Range_Rover73
Is there any major benefits with the 2012 RRS compared to the 2009 - 2011 Supercharged or is it just the powered tailgate?
Post #494427 Mon Apr 25 2016 7:20pm
Camelrock
Don't know about the changes in spec but would go for as new as pos and lowest mileage as long as it's been serviced unless you are going for something special.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #494440 Mon Apr 25 2016 10:02pm
Range_Rover73
What would you consider as low mileage? Less than 50k miles or less than 80k miles?
Post #494446 Tue Apr 26 2016 5:40am
Tim in Scotland
Rule of thumb would be average annual mileage for UK is between 10.000 and 12000 miles, anything significantly below or above that would count as below average or above average. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #494448 Tue Apr 26 2016 6:48am
Range_Rover73
Thank you Thumbs Up
Post #494452 Tue Apr 26 2016 8:16am
