Home > General (L494) > First Service |
lrdaft Member Since: 29 Mar 2009 Location: scotland Posts: 43 |
There is no sump plug!
Mon Apr 18 2016 7:24pm |
KenD Member Since: 27 Feb 2007 Location: Essex Posts: 34 |
Thanks Irdaft, what about the filter, where is that located? |
Mon Apr 18 2016 8:37pm |
Middle of v under the engine cover
Mon Apr 18 2016 8:55pm |
Thanks again Irdaft you've been very helpful. Ok, they can drain the oil via a tube in the engine bay and filter again can be changed from above, why then would they charge me or a new sump plug without taking the underpan off ? I'm blowed if I can see how. |
Tue Apr 19 2016 9:46am |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 |
Had similar fuel leak when my tank had the baffle plates fitted. It was caused by mechanic failing to refit the overflow pipe which allowed diesel to spill out from top of tank. So it only happened if tank was fairly full and vehicle was moving so sloshing the fuel about. |
Tue Apr 19 2016 10:44am |
That sounds very much like my problem, anyway I 've had a word with the Service Manager and he's arranging to check it over. Will let yo know what the out come is. Thanks Bigben. |
Tue Apr 19 2016 6:23pm |
Finally got the RRS back late yesterday. Seems to be OK, but haven't filled it up and given it a good run yet. I was informed that the diesel leak was caused by over spill when fitting the anti slosh mod. They recon that the tank has a double layer and some diesel was trapped in between and slowly seeping out. Is the tank double layered or do they mean the lower protecting sheild below the tank? as it was late when I picked it up nobody could give me a satisfactory answer.
Wed Apr 27 2016 10:39pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
Workshop manual gives both options to drain the oil, via sump plug and through the Vac tube. Also it says that spilling of some oil is unavoidable with vacuum method so you should be able to see some oil spill. Also I would take a photo of the oil level to compare after the service. |
Thu Apr 28 2016 2:51pm |
