![]() | Home > Maintenance & Modifications > Mega flush by Geoff. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
How much please? |
Areas covered to please? John
Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58 ![]() ![]() ![]() |
Probably best you contact him direct to discuss prices, location etc.
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
OK, a lot of missing info... You say Geoff did this for you but you provide no info...
Well you could do what I did when I recently bought my Sport.......... Do your homework then contact the the people that are well recommended on this site and on the sister sites.
Well I suppose I could, yes, valid point but going on just Geoff, which I did, brought up very little in the search so no mention of price, work done or contact info. Which brings me back to my point....
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
To cut a long story short,, a mega flush is a means of changing the Gearbox oil. If the oil is changed just by normal methods,, taking out the plug and letting it drain, not all of the oil actually drains out. A mega flush uses a special machine,,, bit like a dialysis machine, it removes all of the old oil and replaces it with new. Most people have it done as per the Gearbox manufacturers recommendation,, at 75k miles or thereabouts. In the UK prices range from 250 - 300 pounds. The Gearbox is normally reset at the same time so that it basically learns a new set of changes depending on your driving style. 2010 RRS, TDV8
ZF suggest a flush 50-75k or sooner with arduous use, and I can't emphasise enough how important it to get the fluid changed in a timely manner. I second the recommendation for Geoff - he's based in Kent but is mobile and often gets about on flushing trips. |
Thanks Gogsy,
Canrover,, the thing to keep in mind is this process is carried out using a Winns transverse flushing machine,, not a lot of dealers in the UK have them as they are quite hard to get hold of and are not cheap. That is why a lot of dealers simply drop the oil a couple of times to get as much oil out as possible. Have a look on U tube for a one in action and make sure that is the method they use.
Thanks Gogsy,
Hey Gogsy,
Yes, that looks very similar to machine that Geoff has. His machine is made by Wynns.
