Home > In Car Electronics > Playing video files from USB stick |
W33 PHL Member Since: 29 Jun 2007 Location: Sunderland Posts: 33 |
Has anyone managed to play video from a USB stick and if so which format works? I don't seem to be having much luck in getting it to work. I have a 2012 RRS with the 2013 entertainment system.
Sat Apr 16 2016 12:22am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
Yes.
Sat Apr 16 2016 9:06am |
Thanks I'll try it. http://www.weephillie.com |
Sat Apr 16 2016 9:20am |
It finds the file then tries to play it but then comes up with 'device error'. Any ideas? http://www.weephillie.com |
Sat Apr 16 2016 10:18am |
I take it you have generated the Registration Code and gone to the DivX website and Registered it.
Sat Apr 16 2016 10:49am |
Sat Apr 16 2016 10:59am |
Unless you do I don't think it will play.
Sat Apr 16 2016 11:33am |
Thanks Col,
Sat Apr 16 2016 12:48pm |
What size Memory Stick are you using I think 32GB is the max size it will read. I think it needs to be formatted in FAT 32 not NTFS as well.
Sat Apr 16 2016 12:58pm |
As Col says I had to do just that to play videos and Div X films via my USB stick. But my DVD films played straight off.
Sat Apr 16 2016 2:14pm |
Well I'm sort of getting there now. I have managed to get them to play from the USB but cannot seem to get HD even at 720p. When I convert to DivX on the HD setting it doesn't play the file. It however plays when converted at a lesser quality. Is this normal? http://www.weephillie.com |
Sat Apr 16 2016 2:55pm |
Thanks guys for your help. The quality the movies are playing at is quite sufficient and I'm happy with that. It's taken the best part of the day to sort out but we seem to be there now.
Sat Apr 16 2016 4:14pm |
