![]() | Home > Technical > Starter breather |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9037 ![]() ![]() ![]() |
It runs up by the turbo, across the top of the bellhousing and terminates behind the engine just below the windscreen. |
Sorry, forgot to upload the routing info. I guess it's too late now but just in case:
No that's fine RRSTDV8 as not doing the job till Saturday. Just checked the diagram the pipe Lookes different to the breather I've got. I think they have modified the plpe.. 2008 G4 RRSport TDV8 current
The one on mine is white plastic and fits to two breather locations on the starter (solenoid and motor?). They T together and then runs up to behind the engine. When fitted by the LR dealer, it was just casually positioned to vent below the gearbox! Typical LR dealership quality of work. It was only because I checked whether they'd done it correctly that I found out that they hadn't. Suffice to say the dealership was somewhat surprised when I took the vehicle back and demanded it was done correctly. Unsurprisingly, I had to tell them where the information on the correct routing was to be found.
Hi RRSTDV8 thanks for the reply wondering if that's what's caused mine to play up as we where court in the flood in the lakes in December and ended up wading through lots of water. Sounds like I might be looking at the breather the wrong way round as I hadn't realised ther where two breather outlets on the starter |
