Home > General > 2010-2014 Headlights AFS or Not |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
No. Also bear in mind that the conversion with AFS lights has proved to be hit and miss (and no-one has been able to pinpoint the deciding factor) - you may find they won't work. Visiting from DISCO3.CO.UK
Mon Apr 04 2016 6:45am |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 |
Thanks for the response LOW. Is it still a hit and miss even if my 2006 has AfS from factory? |
Mon Apr 04 2016 7:36am |
Yes, 'fraid so. The ECU communicates with the lights by LIN bus, and it seems some modules will communicate and others won't, and as yet, I don't think anyone has found the link as to why. The pre- and post-facelift models use differen't CANBUS bitrates, which means the ECUs aren't cross-compatible, so it's down to whether the lights work with the existing ECU or not. Visiting from DISCO3.CO.UK
Mon Apr 04 2016 7:59am |
thanks buddy |
Mon Apr 04 2016 8:16am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
mnk,
Tue Apr 05 2016 5:22am |
Thanks guyzer,
Tue Apr 05 2016 7:42am |
Mnk,
Tue Apr 05 2016 7:56am |
Thanks Guy, I'll let you know how I get on. |
Tue Apr 05 2016 8:00am |
