![]() | Home > General > 2010-2014 Headlights AFS or Not |
No. Also bear in mind that the conversion with AFS lights has proved to be hit and miss (and no-one has been able to pinpoint the deciding factor) - you may find they won't work. |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
Thanks for the response LOW. Is it still a hit and miss even if my 2006 has AfS from factory? |
Yes, 'fraid so. The ECU communicates with the lights by LIN bus, and it seems some modules will communicate and others won't, and as yet, I don't think anyone has found the link as to why. The pre- and post-facelift models use differen't CANBUS bitrates, which means the ECUs aren't cross-compatible, so it's down to whether the lights work with the existing ECU or not. |
thanks buddy |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
mnk,
Thanks guyzer,
Mnk,
Thanks Guy, I'll let you know how I get on. |
