Front drivers washer not working
Hi. In the frost a couple of weeks ago my front driver wash froze and came off the nozzle. I put it back on and cleaned it out. It worked ok. Yesterday it stopped working all together. I have had a look and the pipe is still connected. Any ideas please help
Cheers matt
Thu Mar 03 2016 8:13pm
Jylee
Maybe the nozzle on the driver side is block, have your try to clear the nozzle with a pin.
Thu Mar 03 2016 9:58pm
Harryfence
Cheers mate. Only cleaned them last week. Didn't think they could block again so fast. But just done it again and they are working. Must be something in tank.
Fri Mar 04 2016 3:39pm
Paddi
Sometimes bugs grow in the tank causing clogged jets. Try keeping the strength of the screenwash up a bit higher to discourage this? You are using proper screenwash and not Fairy Liquid aren't you?
Top tip - pull a long bristle out of a yard broom and use that instead of a pin - less chance of damaging anything 2008 MY Java Black TDV8 HSE
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
