Home > Technical > Front drivers washer not working
Harryfence
Hi. In the frost a couple of weeks ago my front driver wash froze and came off the nozzle. I put it back on and cleaned it out. It worked ok. Yesterday it stopped working all together. I have had a look and the pipe is still connected. Any ideas please help
Cheers matt
Post #489923 Thu Mar 03 2016 8:13pm
Jylee
United States 2007 Range Rover Sport 4.4 V8 HSE Orkney Grey
Maybe the nozzle on the driver side is block, have your try to clear the nozzle with a pin.
Post #489936 Thu Mar 03 2016 9:58pm
Harryfence
Cheers mate. Only cleaned them last week. Didn't think they could block again so fast. But just done it again and they are working. Must be something in tank.
Post #489985 Fri Mar 04 2016 3:39pm
Paddi
Sometimes bugs grow in the tank causing clogged jets. Try keeping the strength of the screenwash up a bit higher to discourage this? You are using proper screenwash and not Fairy Liquid aren't you?
Top tip - pull a long bristle out of a yard broom and use that instead of a pin - less chance of damaging anything Thumbs Up 2008 MY Java Black TDV8 HSE
Post #489987 Fri Mar 04 2016 4:41pm
