Home > Technical > Hdc system fault |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 |
After trying a fee things other owners have listed in many many forums and threads mine took a gamble and some further investigation....
Wed Feb 24 2016 9:35pm |
X77clo Member Since: 24 Feb 2016 Location: Lancashire Posts: 7 |
When the wheel is dead central the 4x4 info on the screen in the middle of the car shows the wheel dead straight aswell |
Wed Feb 24 2016 9:45pm |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 |
I had this issue last year... it was the battery. Banged a new one in and all the warning lights just vanished. Have you tried charging your battery fully? It'll be getting hammered with the current cold weather, especially if you're only making short trips. |
Thu Feb 25 2016 10:01am |
Citizen55 Member Since: 14 Dec 2015 Location: Rollin' in my Five point O (well, 4.2) Posts: 55 |
I had this issue with mine - It was fine when starting up and driving in a straight line, but as soon as I turned the first corner, i.e steering input, then I would also get the warning lights HDC disabled etc, and all the toys (Cruise Control, suspension height and mode etc) were disabled.
Thu Feb 25 2016 10:19am |
this is a good sign. The usual suspects as said are rear bulbs and brake light switch also some say weak battery and brake sensors or angle sensors. hdc fAult from my experience comes up when the car thinks there is an issue with the brakes or the alignment steering and yaw sensor which is as the above post says something to do with the direction and geometry of cars travel also called lateral sensor. |
Fri Feb 26 2016 2:52am |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Best place to pick a new battery up is from the Tayna website. Use the discount code D2BOYS for an extra 5% off. If you order today it will be with you tomorrow.
Fri Feb 26 2016 4:38am |
Thanks for all your response and advice I changed the break light switch today as it was only cheap to do and it still come up with the same faults as before, when I took the break light switch apart it was black in side like I saw on a recent post so looks like it needed doing soon anyway, I have got the car booked in Tuesday to go have its 4 wheel alignment done and sensors re calabratied hopefully this will cure it if not I am ticking my way down the list to find the issue |
Fri Feb 26 2016 6:43am |
When you say every bulb do you mean ever bulb ie fog reverse or just bulbs relating to breaking |
Fri Feb 26 2016 6:46am |
Maybe all bulbs only a 2 more each side and as you go from park to drive you pass through reverse so that bulb gets power maybe worth trying for a few pounds can always keep as spare ... saw osram on ebay about 2.50 a pair.
Tue Mar 01 2016 4:19pm |
