Home > Technical > Hdc system fault
X77clo
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hdc system fault
Hello I am new Owner of a Range Rover sport it is a 2008 tdv8 covered about 115k I have owned the car for 2 months now and never really done much long distance driving i only use the car for pottering around town the car is great with no faults or malfunctions but after about 10 miles of driving I have a few messages that pop up on the dash that say car leans when cornering, hdc system fault special programmes unavailable, suspension lowered. Turn the car on and off and all is happy again for another 10 miles but it only does it after continuasly driving has anyone else experienced this? And what could be causing this fault. I have been reading on the Internet and I can only find battery and break lights/light switch could this apply to my fault codes? It has been in the garage but they can't seem to put there finger on it any help would be great
Thanks mat
Post #488835 Wed Feb 24 2016 9:12pm
SH0X
After trying a fee things other owners have listed in many many forums and threads mine took a gamble and some further investigation....
can you do something... put the steering wheel dead centre then have a look at your screen and tell me if the system shows the steering of the car to be dead on or not?
Post #488838 Wed Feb 24 2016 9:35pm
X77clo
When the wheel is dead central the 4x4 info on the screen in the middle of the car shows the wheel dead straight aswell
Post #488842 Wed Feb 24 2016 9:45pm
zaphod
I had this issue last year... it was the battery. Banged a new one in and all the warning lights just vanished. Have you tried charging your battery fully? It'll be getting hammered with the current cold weather, especially if you're only making short trips.
Post #488883 Thu Feb 25 2016 10:01am
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
I had this issue with mine - It was fine when starting up and driving in a straight line, but as soon as I turned the first corner, i.e steering input, then I would also get the warning lights HDC disabled etc, and all the toys (Cruise Control, suspension height and mode etc) were disabled.
Took it into LR dealer and he said the battery had gone flat (it had been sitting for weeks without starting) at some point.
He said there is a sensor in the roof which determines the direction the car is travelling (i.e directly forward), and another sensor in the steering wheel which determines the steering input, (I think the idea is, if the two sensors don't match, then it thinks the car is understeering so it adjusts the power output to the wheel) - anyways, becasue the battery went flat, these sensors needed re-calibration. They did that and I haven't had a problem since. 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #488888 Thu Feb 25 2016 10:19am
SH0X
this is a good sign.
The usual suspects as said are rear bulbs and brake light switch also some say weak battery and brake sensors or angle sensors.
hdc fAult from my experience comes up when the car thinks there is an issue with the brakes or the alignment steering and yaw sensor which is as the above post says something to do with the direction and geometry of cars travel also called lateral sensor.
Post #488978 Fri Feb 26 2016 2:52am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Best place to pick a new battery up is from the Tayna website. Use the discount code D2BOYS for an extra 5% off. If you order today it will be with you tomorrow.
I believe that you will need a 017 model of battery. The Exide Premium is a popular choice over on the Disco Forum.
Jim
Post #488989 Fri Feb 26 2016 4:38am
X77clo
Thanks for all your response and advice I changed the break light switch today as it was only cheap to do and it still come up with the same faults as before, when I took the break light switch apart it was black in side like I saw on a recent post so looks like it needed doing soon anyway, I have got the car booked in Tuesday to go have its 4 wheel alignment done and sensors re calabratied hopefully this will cure it if not I am ticking my way down the list to find the issue
Post #488991 Fri Feb 26 2016 6:43am
X77clo
When you say every bulb do you mean ever bulb ie fog reverse or just bulbs relating to breaking
Post #488992 Fri Feb 26 2016 6:46am
SH0X
Maybe all bulbs only a 2 more each side and as you go from park to drive you pass through reverse so that bulb gets power maybe worth trying for a few pounds can always keep as spare ... saw osram on ebay about 2.50 a pair.
also when you have the 4x4 display up are there any hight sensors flashing or do any sensors look like they are sitting higher than the others ?
Post #489589 Tue Mar 01 2016 4:19pm
