![]() | Home > General > Steering Vibration |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
Have you had a 4 wheel alignment done?
Markyb Member Since: 10 Feb 2016 Location: Warrington Posts: 2 ![]() ![]() |
Thanks Zaphod!
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Sounds odd, but may be water in tyres. Mine had exactly the same after I bought it and if it was standing there for a while it could do this. Mine was exactly the same, but only started at 70 nothing lower....worth a check
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Do you feel pulsing through the brake pedal under hard braking ? When he replaced rear disc - did he do pads as well ? If other disc was not worn or warped - maybe ok not to replace. I'm not sure how you can tell just by looking that front discs are ok - but I would get them measured for run out before replacing - so you know if there was an issue -brake shop should have a tool to do this. I assume front wheel bearings and track/tie rod ends check out ok ? |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
Get this car on a ramp and arms bushes etc inspected - any garage can do it or an MOT place will do it and be more clued up what to look for
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 ![]() ![]() ![]() |
It is not a practice to replace only one rotor, but i don't think Your vibration is one new/old rotor. We need more info to trouble shot. What cause the steering vibration...Is it vibrate when brake is apply...did the mechanics replace the pad along with the rear rotor. In most cases, vibration are caused by wrap rotors, bad wheel balance, or bad suspensions. All these problems can be touble shoot by any mechanics. |
