![]() | Home > Technical > Front lower arms |
I would recommend having 4 wheel alignment carried out,, this is the norm after replacing the front arms 2010 RRS, TDV8
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
Will do thanks for reply |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
They should have set the ride height (gap between centre of half shaft and edge of wheel arch) before tightening the lower arm bolts. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
It sets the bushes to the correct height, so there is no tension on the bushes when the car is at normal ride height ![]() |
Will it cause a problem in future or best to get them to redo |
It may cause premature wear on the bushes |
