Home > Technical > Front lower arms
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Front lower arms
Can anyone let know is there any importance with measuring distance from centre of wheel to wheel arch when replacing lower arms as the garage I had fit them didn't know anything about the measurement process
Post #487935 Thu Feb 18 2016 5:24pm
gogsy1956
I would recommend having 4 wheel alignment carried out,, this is the norm after replacing the front arms 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #487952 Thu Feb 18 2016 6:45pm
Cosmo15555
Will do thanks for reply
Post #487954 Thu Feb 18 2016 6:48pm
They should have set the ride height (gap between centre of half shaft and edge of wheel arch) before tightening the lower arm bolts. 2012 SDV6 - it's missing a couple of cylinders
Post #487958 Thu Feb 18 2016 7:02pm
Disco_Mikey
Re: Front lower arms
It sets the bushes to the correct height, so there is no tension on the bushes when the car is at normal ride height Thumbs Up
Post #487960 Thu Feb 18 2016 7:07pm
Cosmo15555
Will it cause a problem in future or best to get them to redo
Post #487976 Thu Feb 18 2016 8:23pm
Disco_Mikey
It may cause premature wear on the bushes
Post #487980 Thu Feb 18 2016 8:30pm
