Home > General > Advice for Newbie Please
Blackadderyork
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi and please forgive me if this question has been asked before - I'm getting to grips with the forum search facility but am no exert yet!
I am keen to know if there is a specific sequence to connect a 12v tyre compressor to the battery with croc coips. I'm familiar with the standard 'red followed by black' but have been a bit concerned by comments that suggest the 'brains' of my era may be rattled if the normal sequence for connecting to other vehicles is followed.
Could anyone possibly put my mind at rest and offer the correct method please?
Many thanks
Andy
Post #484298 Fri Jan 08 2016 5:32pm
Tim in Scotland
Firstly, welcome to the forums.
Sorry not a lot of help but convert the crocs to a cigarette lighter plug.............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #484320 Fri Jan 08 2016 9:20pm
Welcome top the forum Thumbs Up
I always connect the positive (RED) lead first, but disconnect the RED lead first when disconnecting.
Post #484325 Fri Jan 08 2016 9:58pm
DrRob
Disconnect earth lead first, reconnect last.....what I was taught.
i think most Sports have an earth post so use that..... Visitor from fullfatrr.com
Post #484341 Sat Jan 09 2016 9:28am
Now he is confused .. Laughing
Dr Rob, you was taught wrong. Embarassed
Post #484343 Sat Jan 09 2016 9:46am
Yep disconnect Negative (Earth) First and Reconnect Last that is what I was taught as well, If it's wrong I have been doing it wrong for longer than a lot of Guys on the forum have been Born.
I think you are wrong Ady but stand to be corrected.
Post #484346 Sat Jan 09 2016 10:05am
Lost for Words
If we are talking about a battery, always disconnect the negative before positive, and reverse to reconnect (the reason being, that the whole car is grounded, so if you touch the car when removing the positive terminal, you'd complete a circuit).
In terms of a compressor or other device, it makes as good as no difference but there would be a tiny, tiny, tiny potential benefit to connecting the negative first - for basically the same reason in the event of faulty wiring etc.
If connecting jump leads to another vehicle/battery, I'd always connect the positive first, then negative, because it prevents the possibility of shorting via the vehicle ground.
Thumbs Up Visiting from DISCO3.CO.UK
Post #484347 Sat Jan 09 2016 10:05am
Blackadderyork
Dear All
Many thanks for your quick replies. I think that as it's a tyre compressor I'm using rather than replacing the battery or using jump leads, I'll take the low risk option and connect the negative first to ground it in case there is anything iffy relating to the circuitry of either my car or compressor.
Grateful for your support!
Andy
Post #484348 Sat Jan 09 2016 10:42am
This is what I did, just hard wired in a Anderson Plug and then fitted a plug to my Compressor, C-tek etc. so it's basically just "Plug and Play"
Post #484349 Sat Jan 09 2016 10:50am
TheWojtek
Re: Advice for Newbie Please
I'm afraid it's quite the opposite. You disconnect the BLACK (negative/ground) first.
EDIT - seems I've been beaten to this by people waking up earlier than myself. Well, at least I reiterate this: BLACK disconnects first Rolling with laughter Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #484351 Sat Jan 09 2016 11:10am
Blackadderyork
Thanks wojtek, but I'm not looking to disconnect my battery, just connect a tyre compressor using croc clips. I appreciate your reply.
Col, that looks a neat solution and I assume there is a straightforward means to connect the wire for the anderson to the battery. My car is a 2011 RRS hse and there isn't much room under the lid.
Andy
Post #484352 Sat Jan 09 2016 11:28am
The car's a MY13 5.0L S/C and there is plenty of room as I didn't connect direct to battery, I will take a couple of pictures of the connections later if you want.
Post #484354 Sat Jan 09 2016 11:53am
Embarassed Embarassed I stand corrected Embarassed
Just goes to show, you can't believe everything you are told. Laughing
Apologies Dr Rob. Thumbs Up
Post #484356 Sat Jan 09 2016 12:22pm
DrRob
All good here Thumbs Up Visitor from fullfatrr.com
Post #484359 Sat Jan 09 2016 1:05pm
Blackadderyork
Col, that would be great thanks.
Andy
Post #484362 Sat Jan 09 2016 1:25pm
