Home > General > Advice for Newbie Please
Not the best pictures only it's a bit crap outside at the minute.
Post #484366 Sat Jan 09 2016 2:45pm
Blackadderyork
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Thanks Col. I can see the +ve terminal but can't work out how the anderson is connected. Any chance you could provide a quick explanation if you get chance? No problem if not. Cheers
Andy
Post #484370 Sat Jan 09 2016 4:23pm
Hi
Negative End just connected to Earth Stud by corner of Air Filter Housing shown in pictures, Positive connected to Battery link lead in Engine Bay Fuse Box. The other end's of the Cable just soldered to the Terminals for the Anderson Plug which are both the same just pushed into the relative Neg. and Pos. positions on the Plug it's self.
Haven't got around to securing the Anderson Plug yet, just needs Bolting to Front Slam panel,Inner Wing Valance or somewhere convenient. I used a old c-tek extension lead I had in the garage for the two core cable as it already had two ring terminals and 15amp fuse/holder fitted. Left it about a Meter or so long to have enough length to connect to Anderson Plug and route it to suitable Mounting Point.
Post #484383 Sat Jan 09 2016 7:08pm
Blackadderyork
That's great, thanks Col.
Andy
Post #484388 Sat Jan 09 2016 7:49pm
