Home > General > Advice for Newbie Please |
Firstly, welcome to the forums.
Fri Jan 08 2016 9:20pm |
Welcome top the forum
Fri Jan 08 2016 9:58pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Disconnect earth lead first, reconnect last.....what I was taught.
Sat Jan 09 2016 9:28am |
Now he is confused ..
Sat Jan 09 2016 9:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Yep disconnect Negative (Earth) First and Reconnect Last that is what I was taught as well, If it's wrong I have been doing it wrong for longer than a lot of Guys on the forum have been Born. I think you are wrong Ady but stand to be corrected. Cheers Col |
Sat Jan 09 2016 10:05am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
If we are talking about a battery, always disconnect the negative before positive, and reverse to reconnect (the reason being, that the whole car is grounded, so if you touch the car when removing the positive terminal, you'd complete a circuit).
Blackadderyork Member Since: 08 Jan 2016 Location: York Posts: 6 |
Dear All
Sat Jan 09 2016 10:42am |
This is what I did, just hard wired in a Anderson Plug and then fitted a plug to my Compressor, C-tek etc. so it's basically just "Plug and Play"
Sat Jan 09 2016 10:50am |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
I'm afraid it's quite the opposite. You disconnect the BLACK (negative/ground) first. EDIT - seems I've been beaten to this by people waking up earlier than myself. Well, at least I reiterate this: BLACK disconnects first Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Sat Jan 09 2016 11:10am |
Thanks wojtek, but I'm not looking to disconnect my battery, just connect a tyre compressor using croc clips. I appreciate your reply.
Sat Jan 09 2016 11:28am |
The car's a MY13 5.0L S/C and there is plenty of room as I didn't connect direct to battery, I will take a couple of pictures of the connections later if you want.
Sat Jan 09 2016 11:53am |
I stand corrected Just goes to show, you can't believe everything you are told. Apologies Dr Rob. |
Sat Jan 09 2016 12:22pm |
All good here Visitor from fullfatrr.com
Sat Jan 09 2016 1:05pm |
Col, that would be great thanks.
Sat Jan 09 2016 1:25pm |
