Home > Maintenance & Modifications > Paddle shift upgrade on my2010 |
JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89 |
I did this on mine you might well need a new clock spring
Wed Jan 18 2012 8:31pm |
But just for paddle shift you will only require the paddles a loom for the steering wheel and a software upgrade to enable them
Wed Jan 18 2012 8:36pm |
swalker900 Member Since: 12 Sep 2010 Location: Bury Posts: 46 |
Thanks Julian. - yes got them very Pleased - sent pm earlier MY2010 3.0 TDV6 HSE, Zermatt silver/Ebony/walnut, privacy, side steps, rubber mats and standard otherwise... |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sorry, sort of related hijack, how easy is it to add the heated wheel to a car without and what is needed? ON THE WAY: BMW F21 M140i
Thu Jan 19 2012 3:44pm |
To add a heated wheel you will need the heated wheel itself, you will also need to check the "Clock spring /Rotary coupler"
Thu Jan 19 2012 3:52pm |
Thanks JUCOTT01, so how is it activated, do I need a button, or is it activated with the rear/front screens or the seats ? ON THE WAY: BMW F21 M140i
Thu Jan 19 2012 4:06pm |
When you aquire your new wheel with the heated element in it it will have a button on the opposite side to the ACC it is part of the new wheel RRS MY11 BALI BLUE OVERFINCH |
Thu Jan 19 2012 4:11pm |
^^^ Thanks mate
Thu Jan 19 2012 4:13pm |
Give Pete at Bell Autos a shout he might well have a wheel in stock
Thu Jan 19 2012 4:19pm |
Stuart's the man Member Since: 02 Jan 2012 Location: Glasgow Posts: 35 |
plug and play once you get bits, think you need to run a power wire up to switch, this has been well covered on d3 site |
Sat Jan 28 2012 12:27pm |
mgadel Member Since: 08 Nov 2015 Location: Adelaide Posts: 3 |
Is the steering wheel air bag the same in the RRS and the D4 ?
Sun Nov 08 2015 4:29pm |
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 |
Fitting just the paddle shifters requires nothing more than plugging them in on the right switch pack then enabling them in the CCF. If adding heated steering wheel, thats when you need the new clock spring.
Sun Nov 08 2015 8:42pm |
raheelc Member Since: 28 Dec 2015 Location: Virginia Posts: 5 |
I am planning on adding the paddle shifters to my 2010 RRS too. My vehicle already has a heated steering wheel, so do I only need the paddle shifters and new rear cowl? Where can I buy the appropriate cowl from (been looking online but haven't been able to determine whether it's the appropriate one or not)?
Mon Dec 28 2015 3:36am |
