Home > Maintenance & Modifications > Paddle shift upgrade on my2010
swalker900
Hi
Can anyone advise if adding paddle shifters to steering wheel and plugging in, will I then need diagnostics to get working, or will they work straight away?
Thanks MY2010 3.0 TDV6 HSE, Zermatt silver/Ebony/walnut, privacy, side steps, rubber mats and standard otherwise...
Post #328635 Wed Jan 18 2012 8:20pm
JUCOTT01
I did this on mine you might well need a new clock spring Crying or Very sad
This fits behind your steering wheel and has all the power connections to your wheel you WILL require one with a heated element socket on it if you are putting a heated element on it as well
£250 ish from land rover
And yes you will require a software mod to enable the paddleshift
Did you get the trims ?? RRS MY11 BALI BLUE OVERFINCH
Post #328639 Wed Jan 18 2012 8:31pm
JUCOTT01
But just for paddle shift you will only require the paddles a loom for the steering wheel and a software upgrade to enable them
you will also need a new back for the wheel ,this will have the cutouts for the paddles Very Happy RRS MY11 BALI BLUE OVERFINCH
Post #328641 Wed Jan 18 2012 8:36pm
swalker900
Thanks Julian. - yes got them Very Happy very Pleased - sent pm earlier MY2010 3.0 TDV6 HSE, Zermatt silver/Ebony/walnut, privacy, side steps, rubber mats and standard otherwise...
Post #328642 Wed Jan 18 2012 8:36pm
Sorry, sort of related hijack, how easy is it to add the heated wheel to a car without and what is needed? ON THE WAY: BMW F21 M140i
Post #328775 Thu Jan 19 2012 3:44pm
JUCOTT01
To add a heated wheel you will need the heated wheel itself, you will also need to check the "Clock spring /Rotary coupler"
Which is located behind the wheel.
The coupler must have a plug socket on it for the heated element
If you have the correct rotary coupler fitted its just a case of putting the new wheel on
No software update required Thumbs Up Thumbs Up RRS MY11 BALI BLUE OVERFINCH
Post #328777 Thu Jan 19 2012 3:52pm
Thanks JUCOTT01, so how is it activated, do I need a button, or is it activated with the rear/front screens or the seats ? ON THE WAY: BMW F21 M140i
Post #328782 Thu Jan 19 2012 4:06pm
JUCOTT01
When you aquire your new wheel with the heated element in it it will have a button on the opposite side to the ACC it is part of the new wheel Smile RRS MY11 BALI BLUE OVERFINCH
Post #328785 Thu Jan 19 2012 4:11pm
^^^ Thanks mate Thumbs Up
Now off to find out if I have the plug and if I can source a wheel Razz ON THE WAY: BMW F21 M140i
Post #328789 Thu Jan 19 2012 4:13pm
JUCOTT01
Give Pete at Bell Autos a shout he might well have a wheel in stock Thumbs Up
He might also be able to tell you for sure about your rotary coupler !!
I know that land rover only supply heated ready couplers in there parts dept.
Therefore if by chance for some strange reason your coupler developed a fault the one they would replace it with would be fine for a heated element Whistle Whistle Whistle Whistle Whistle Whistle RRS MY11 BALI BLUE OVERFINCH
Post #328791 Thu Jan 19 2012 4:19pm
Stuart's the man
plug and play once you get bits, think you need to run a power wire up to switch, this has been well covered on d3 site
Post #329897 Sat Jan 28 2012 12:27pm
mgadel
Australia
Is the steering wheel air bag the same in the RRS and the D4 ?
Regards Adrian
Post #479135 Sun Nov 08 2015 4:29pm
jeffhunt
Fitting just the paddle shifters requires nothing more than plugging them in on the right switch pack then enabling them in the CCF. If adding heated steering wheel, thats when you need the new clock spring.
For me the hardest part was removing the airbag, you can but the tool (hook) for £20, I made one out of an old wire coat hanger, bit fiddly getting it in the right place to pull the spring but no major issues. Powerful.co.uk has a good video on hoe to remove the airbag. Don't forget to disconnect the battery.
In addition to the paddles, you will need the loom and also a new rear cowl for the steering wheel with the appropriate cutouts on it.
Post #479159 Sun Nov 08 2015 8:42pm
raheelc
United States
I am planning on adding the paddle shifters to my 2010 RRS too. My vehicle already has a heated steering wheel, so do I only need the paddle shifters and new rear cowl? Where can I buy the appropriate cowl from (been looking online but haven't been able to determine whether it's the appropriate one or not)?
Is there a link someone can provide for a DIY?
Post #483401 Mon Dec 28 2015 3:36am
