![]() | Home > General > general |
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
Hi. Can anyone confirm whether all tdv8 sports come with the motorised steering column
Thanks for the info. I have just put a deposit against a 2007 / 57 plate tdv8 sport. 1 owner full Lrdh and only 48k on the clock.
My TDV8 is a 08MY 57-plate and doesn't have the motorised column. As you say, one less thing to go wrong... |
Thanks for the info it is really helpful.
No, they were not a factory fit, unless specified |
No, the tow pack was optional on all RRS's although a lot of cars ordered for dealer stock were ordered with it. The slot for the demountable towhook was there on all cars but the electrics weren't and if you specced them then the dealer only needed to connect them. If the two hook is a permanent mount one then it is possible that it was a factory/dealer fitted one but more likely to be an aftermarket one. There were several versions of electrics available too, for example on both my 2005 and 2007MY RRS's I had the single plug electrics as I only towed a trailer and didn't need caravan electrics.What LR charges for a tow kit now is ludicrous, my current RRS was a dealers stock order that I took before it was built but I couldn't change any spec as I bought it 2 days before it was built. Iasked about fitting the electrically deployed tow hook and through the dealer itwas going to be more than £2000................ so I have done without and us e my Defender to haul my trailer instead.
The RRS2 tow pack requires a replacement subframe at the rear which, on LR's parts prices, will always be expensive. Add in a dealer's £100++/hour charges and I can see why it would be expensive to fit.
Are the dedicated towing electric sockets plug in and play or do they need configuring to the vehicle. |
On a 57 plate, they will work without enablement. |
