Home > General > general
Lonerangerv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
general
Hi. Can anyone confirm whether all tdv8 sports come with the motorised steering column
Cheers.
Phil.
Post #482580 Wed Dec 16 2015 2:12pm
Tim in Scotland
No only 2008MY onwards have it, if the car has the phone cradle fitting under the centre cubby box lid then 99% certain that it will not have a motorised steering column. The change came in at the change from 2007MY to 2008MY. I took a 2007MY car with a healthy discount after 2008MY had been launched because it was phisically at the dealership and I felt that as I am the only person that drove the car I could manage with a manual adjustment for the steering column! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #482583 Wed Dec 16 2015 2:38pm
Lonerangerv8
Thanks for the info. I have just put a deposit against a 2007 / 57 plate tdv8 sport. 1 owner full Lrdh and only 48k on the clock.
I suppose the manual column is something less to go wrong.
Cheers.
Phil.
Post #482688 Thu Dec 17 2015 11:32am
My TDV8 is a 08MY 57-plate and doesn't have the motorised column. As you say, one less thing to go wrong... Thumbs Up
Oh, if you didn't already know, the VIN will tell you if it's a 07MY or 08MY. Look for the number before the last A:
E.g. SALLSAA237A123456 for 07MY, SALLSAA238A123456 for 08MY TDV8
(SAL = Land Rover, LS = Range Rover Sport, AA = Standard 4 door body type, 2 = TDV8, 3 = RHD, 7 or 8 for the MY, A123456 is unique serial number)
BTW, other engine codes are: 1=2.7 TDV6, 3=4.2 SC petrol, 5=4.4 V8 2012 SDV6 - it's missing a couple of cylinders
Post #482689 Thu Dec 17 2015 11:45am
Lonerangerv8
Thanks for the info it is really helpful.
Can anyone tell me if the towing electrics are factory fitted on all RRS's. ?
Post #482706 Thu Dec 17 2015 3:11pm
Disco_Mikey
No, they were not a factory fit, unless specified Thumbs Up
Post #482707 Thu Dec 17 2015 3:13pm
Tim in Scotland
No, the tow pack was optional on all RRS's although a lot of cars ordered for dealer stock were ordered with it. The slot for the demountable towhook was there on all cars but the electrics weren't and if you specced them then the dealer only needed to connect them. If the two hook is a permanent mount one then it is possible that it was a factory/dealer fitted one but more likely to be an aftermarket one. There were several versions of electrics available too, for example on both my 2005 and 2007MY RRS's I had the single plug electrics as I only towed a trailer and didn't need caravan electrics.What LR charges for a tow kit now is ludicrous, my current RRS was a dealers stock order that I took before it was built but I couldn't change any spec as I bought it 2 days before it was built. Iasked about fitting the electrically deployed tow hook and through the dealer itwas going to be more than £2000................ so I have done without and us e my Defender to haul my trailer instead.
BTW if your car has the removable tow hook then check that it has had the recent recall on them carried out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #482708 Thu Dec 17 2015 3:18pm
The RRS2 tow pack requires a replacement subframe at the rear which, on LR's parts prices, will always be expensive. Add in a dealer's £100++/hour charges and I can see why it would be expensive to fit.
No doubt the aftermarket will make one available at a significant saving on LR's prices. 2012 SDV6 - it's missing a couple of cylinders
Post #482713 Thu Dec 17 2015 3:42pm
Lonerangerv8
Are the dedicated towing electric sockets plug in and play or do they need configuring to the vehicle.
Post #482721 Thu Dec 17 2015 4:15pm
Lost for Words
On a 57 plate, they will work without enablement. Thumbs Up
(NB: The prevention of automatic height changes in special programs etc. needs enablement to apply, but that's not really important.) Visiting from DISCO3.CO.UK
Post #482723 Thu Dec 17 2015 4:25pm
