Home > Maintenance & Modifications > Did an oil change today for 1st time nightmare
Andym418
United Kingdom 2008 Range Rover Sport TDV8 HST Lugano Teal
I have a TDV8 and decided to give it a oil change for first time since I got it ended up with oil everywhere. What a stupid idea putting sump plug on side of sump. I took this out and oil shot all over bottom arms then dripped all over my drive along with spraying everywhere else with the wind blowing it everywhere but in the oil catch can I had underneath.
Also what's the idea of the 2 sump plugs? I took out one facing ground first and hardly anything came out?
Post #482057 Wed Dec 09 2015 8:40pm
Ned
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
Sorry Andy but I can't help but chuckle I did the same years ago 😀😀😀😀
Post #482069 Wed Dec 09 2015 10:03pm
Andym418
Yes it made a mess. I've always done my own oil changes and servicing as I like to know which oil etc is in and enjoy it when I get time but never ended up with half the oil on the drive. The Mrs isn't too happy. Plenty of newspaper and rags next time
Post #482072 Wed Dec 09 2015 10:09pm
Ned
Well I forgot to put the sump plug back wounderd why it was taking so much oil nearly got a divorce over it 😀.
Post #482080 Wed Dec 09 2015 10:51pm
Paddi
Agree it is a silly design. For years now I have always used a massive storage box to catch the oil and even then put big sheets of cardboard over the whole area. Someone at a dealership told me the second plug is something to do with the turbos (maybe the oil feed system?).
Sometimes wonder if garages don't bother with the second plug and thats why the turbo oil feed gets clogged with sludge causing catastrophic turbo failure? 2008 MY Java Black TDV8 HSE
Post #482082 Wed Dec 09 2015 11:08pm
Disco_Mikey
For future reference, the oil filter box folds in half, wedges nicely between the sump and chassis, and guides the oil gracefully into the tray underneath Thumbs Up
Post #482086 Wed Dec 09 2015 11:27pm
Camelrock
D/M now that's just giving our trade secrets away Smile 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #482106 Thu Dec 10 2015 11:37am
Andym418
Cheers Mikey will do that next time.
How often are most of you changing the oil to keep on top? I was thinking around every 5000miles to hopefully keep on top of turbo issues. It had 2 new ones at 43,000 and on 64,000 now so shouldn't get any trouble for a while hopefully.
Post #482111 Thu Dec 10 2015 12:35pm
Camelrock
Change the oil and filter on mine every 5000, use good oil and always drive on light throttle on warm up and let the turbos cool down before turning the engine off (drives the Mrs nuts) sitting there with the engine ticking over but it's cheaper than replacing the turbos. If I ever have problems then it's one of those things but I've done what I could Thumbs Up 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #482120 Thu Dec 10 2015 2:28pm
Disco_Mikey
I change the oil in my own car every 10k miles. The modern intervals of 15/16k+ is waaaay to long, even for having fancy long life oil
If I were running a TDV8, I'd be doing the oil every 6k miles
But the post above is also very wise. I do it with every car I own, petrol and diesel, turbocharged or otherwise Thumbs Up
Post #482122 Thu Dec 10 2015 2:44pm
chopperneil
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Planning on doing a interim change on mine shortly, have had the oil for a month but no time to do it as yet! as far as doing it on the drive if i lock it in off road height and chock the wheels is that enough space to get under it? I have a couple of axle stands as well that i can put under the chassis just in case!
is there any pics anywhere of where the sump plugs are or is it obvious once the engine cover is off? and what do i need from the steelers? a filter and 2 sump plugs?
Post #486568 Thu Feb 04 2016 1:59pm
chopperneil
found a thread detailing the procedure with pics!
thanks anyway
Post #486569 Thu Feb 04 2016 2:15pm
chopperneil
The sunshine got the better of me so popped to the local stealer and got the filter and plugs whilst warming up the motor! put it at off road height and put a old double duvet under the front! oil drained without to much mess, ended up using a more rigid piece of cardboard I had to direct the oil but it worked ok, i need a bigger catch can though! Mine holds around 6 or 7 litres so took no risks and interrupted the flow and drained it a couple of times. new filter and o ring fitted and added 8 litres of oil in, let it run briefly and then checked and added another litre, hard to tell on the dipstick where it is but will check it again after a run tomorrow.
All in all pretty simple to do with no dramas glad i got the first one out the way and now know how to do it!
Post #486575 Thu Feb 04 2016 5:13pm
Tyrefitter
DM what's the best oil for a 2012 sdv6 as I'm going to change mine,,I've always used millers oils in the past with high performance engines & changed every 5000 & the oil I've removed as always been as clean as when I put it in..also is it advisable to do a engine oil flush.someone mentioned about 2 sump plugs,has the sdv6 got 2.?
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #486594 Thu Feb 04 2016 7:57pm
flack
Getting underneath the car is old hat now to drain the oil, I always use an oil extractor, no mess and easy to dispose of.
Flack Thumbs Up
Post #486596 Thu Feb 04 2016 8:08pm
