Home > General > Advice when leaving car
Panavia man
Can anyone advise me on what to do when leaving my TDV8 for 3 weeks? I've read lots of posts about flat batteries when people leave them for a while. . Thanks
Post #481012 Fri Nov 27 2015 12:55pm
Camelrock
I've left mine for the odd week and never had any problems, but you could get one of those small solar panels that clip onto your battery and keep it topped up or you could disconnect your battery which is fine if it's in garage and left unlocked but a pain if left on the street as you're then have to use the man lock in the pass door to get in again. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #481014 Fri Nov 27 2015 1:10pm
Panavia man
Ok thanks for the advice- I can leave it secure so sounds like battery disconnect might be best - so should I remove both terminals? Thanks
Post #481017 Fri Nov 27 2015 1:44pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Just remove the -ve lead as it's usually easier, but either will do. No need to take them both off.
Post #481019 Fri Nov 27 2015 2:08pm
Panavia man
Cheers for that
Post #481020 Fri Nov 27 2015 2:19pm
Lost for Words
Never touch the positive terminal with the negative still attatched - thus you should remove the negative or both, but not just positive. Thumbs Up Visiting from DISCO3.CO.UK
Post #481022 Fri Nov 27 2015 2:43pm
Panavia man
Ok understood - thank you Thumbs Up
Post #481023 Fri Nov 27 2015 2:45pm
smiler148
Hi.
I often leave my RR S/C sitting for 3 to 4 weeks at a time. While the battery has never been totally flat there has been the odd ocasion where it would throw some codes due to the battery being low.
I noe leave it on a solar powered charger when gone and never had a problem since.
Post #481025 Fri Nov 27 2015 3:40pm
Panavia man
Thanks for that. Appreciate the feedback
Post #481026 Fri Nov 27 2015 3:45pm
Panavia man
Do you connect your solar charger via the EOBD connector and leave the panel on the dash? Thanks
Post #481027 Fri Nov 27 2015 4:18pm
DrRob
"Disconnect earth lead first, reconnect last".......that's what I was taught Thumbs Up Visitor from fullfatrr.com
Post #481028 Fri Nov 27 2015 4:18pm
Panavia man
Thank you Dr Rob Thumbs Up
Post #481029 Fri Nov 27 2015 4:20pm
DrRob
You got tow electrics fitted? If yes, get an adaptor lead for a ctek charger and you can trickle charge whilst away..... Visitor from fullfatrr.com
Post #481030 Fri Nov 27 2015 4:24pm
DrRob
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html Visitor from fullfatrr.com
Post #481031 Fri Nov 27 2015 4:24pm
Ideally connect a Ctek to it to keep the battery charged. You can connect it up to the battery and lock the bonnet if you don't have the option of using the towing electrics to connect to.
If you decide to disconnect the battery, make sure you let the car go to sleep first. Unlock the car, unlock the bonnet and then go and have a cup of tea. The EMS will then go to sleep gracefully. I think it takes 2 minutes for the EMS to shut down so worth leaving it a few just to be sure. 2012 SDV6 - it's missing a couple of cylinders
Post #481036 Fri Nov 27 2015 5:59pm
