Home > General > Advice when leaving car |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I've left mine for the odd week and never had any problems, but you could get one of those small solar panels that clip onto your battery and keep it topped up or you could disconnect your battery which is fine if it's in garage and left unlocked but a pain if left on the street as you're then have to use the man lock in the pass door to get in again. 2008 G4 RRSport TDV8 current
Fri Nov 27 2015 1:10pm |
Panavia man Member Since: 27 Oct 2015 Location: North west Posts: 94 |
Ok thanks for the advice- I can leave it secure so sounds like battery disconnect might be best - so should I remove both terminals? Thanks |
Fri Nov 27 2015 1:44pm |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
Just remove the -ve lead as it's usually easier, but either will do. No need to take them both off. |
Fri Nov 27 2015 2:08pm |
Cheers for that |
Fri Nov 27 2015 2:19pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Never touch the positive terminal with the negative still attatched - thus you should remove the negative or both, but not just positive. Visiting from DISCO3.CO.UK
Fri Nov 27 2015 2:43pm |
Ok understood - thank you |
Fri Nov 27 2015 2:45pm |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 |
Hi.
Fri Nov 27 2015 3:40pm |
Thanks for that. Appreciate the feedback |
Fri Nov 27 2015 3:45pm |
Do you connect your solar charger via the EOBD connector and leave the panel on the dash? Thanks |
Fri Nov 27 2015 4:18pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
"Disconnect earth lead first, reconnect last".......that's what I was taught Visitor from fullfatrr.com
Thank you Dr Rob |
Fri Nov 27 2015 4:20pm |
You got tow electrics fitted? If yes, get an adaptor lead for a ctek charger and you can trickle charge whilst away..... Visitor from fullfatrr.com
Fri Nov 27 2015 4:24pm |
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html Visitor from fullfatrr.com
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Ideally connect a Ctek to it to keep the battery charged. You can connect it up to the battery and lock the bonnet if you don't have the option of using the towing electrics to connect to.
Fri Nov 27 2015 5:59pm |
