Home > General > Stop/start button
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Stop/start button
I want to change the stop start button on my Santori Black RRS my12 for an illuminated version on sale on EBay.
Has anyone ever done this and how easy is it to get at/remove the button?
Post #480591 Sat Nov 21 2015 3:53pm
midsman
Just a quick note, my Sept 12 RRS HSE Luxury has a backlit stop start button. The backlight is red. 2015 Range Rover Sport Autobiography Dynamic SDV6
2012 Range Rover Sport SDV6 HSE Luxury- Santori Black with Autobiography Ebony/ Ivory interior- SOLD
Post #480618 Sat Nov 21 2015 10:32pm
LG8340
Hi and thanks for your reply and confirmation that you have done exactly what I want to do.
Question is where did you source the backlit, red stop/start button and how did to get to the old one for removal?
Your help would be very appreciated.
Mine is also a Sep 2012 Sport!
Regards
Michael
Post #480619 Sat Nov 21 2015 10:48pm
Slightly confused here if you have a Sept 2012 car it should already have a illuminated in Red stop/start button, also you say it's a TDV8 but I thought they dropped the TDV8 engine in 2010/11.
Post #480623 Sat Nov 21 2015 11:32pm
LG8340
No! Mine is an SDV6 not a TDV6 and it does not have an illuminated stop/start button. I am however mistaken about the ref date. Mine is Jun '12
I test drove a MY15 Sport last week and it hadn't got one either!
Could it possibly be that whoever you bought your car from retro-fitted it?
Regards
Michael
Post #480624 Sat Nov 21 2015 11:50pm
LG8340
BTW Col I attach a photo of the stop start button that I hope to fit.
Post #480625 Sun Nov 22 2015 12:01am
Hi
Your avatar on the left hand side has your car as a TDV8. L/R only list one Start/Stop switch for the 10/13 Sport from
Vin. AA000001 on. Pt/No. LR014015
You would need to check the connector on the rear of that switch to make sure it is compatible with the plug on your harness.
Original Switch
Post #480626 Sun Nov 22 2015 12:06am
LG8340
Thank you!
I have now updated my Avatar
M
Post #480627 Sun Nov 22 2015 12:20am
midsman
Confirm what Col said, in that my RRS had a factory fitted red back light to the stop/start button. 2015 Range Rover Sport Autobiography Dynamic SDV6
Post #480637 Sun Nov 22 2015 10:15am
LG8340
Now it's my turn to be confused.
I've identified part no. LR014015 and it is a stop start button.
However it is NOT red nor illuminated. It's just as fitted to my MY12 RRS Sport (black).
Nevertheless two of you confirm that MY12 RRS are fitted with illuminated stop start buttons!
Can anyone shed light on this please?
Post #480640 Sun Nov 22 2015 10:55am
I replaced my Stop/Start Button recently due to the lettering being worn, and replaced it with LR014015 and can assure you when the lights are turned on the lettering is illuminated Red. The Switch it's self is not Red but Black and Noble.
Post #480641 Sun Nov 22 2015 11:02am
LG8340
Thanks for that clarification! That seems to nail it so far as illumination is concerned.
I'd still really like a full on RED button as in photo! I can't believe that it can be a major issue to fit it even though it isn't a LR part with a matching connector. An adaptation would seem possible! It's just a contact switch after all!
Post #480642 Sun Nov 22 2015 11:10am
I am not a Auto Electrician but it also act's as the Ignition Switch should you not want to start the car, so the Switch has three function, Ignition, Start and Stop which I assume are somehow controlled by a ECU on the car so I don't think it will be as simple as splicing a few wires.
As I said I am not a Auto Electrician though, so it maybe as simple as that. Should you have a L/R warranty on the car I would imagine it would certainly invalidate that if you modify the wiring.
Post #480645 Sun Nov 22 2015 11:48am
LG8340
Hi Col
The price (£21) of the LR OEM push button switch suggests that it has no built-in intelligence.
Are you able to send over a photo of the switch whilst illuminated?
Meanwhile I shall keep you informed of any progress.
BTW I have taken out a LR extended warranty but not had cause to call upon it as yet, Has anyone any experience in that connection?
Regards
Michael
Post #480648 Sun Nov 22 2015 12:14pm
scrumps
Just my 10p's worth.
Both my 13.5MY HSE Black and SWMBO's 14MY Disco HSE have the same stop start button.
It's black/ white normally and lights up red/ black when you switch the headlights on.
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #480769 Mon Nov 23 2015 7:16pm
