Home > General > Stop/start button |
I'm pretty sure that the button is just a momentary on off button, all the logic for ignition on is done by ecu. You could put almost any switch wired in there, maybe even a nuclear bomb button as long as it was momentary on off and then illuminated however you wanted.
Mon Nov 23 2015 8:18pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
I just thought it might be a bit more than just a on /off switch as there are 4 terminal pins on the back and a small circuit board inside the switch.
Mon Nov 23 2015 9:32pm |
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 |
Those of you who point out that the stop/start RRS button is illuminated are right.
Sun Dec 13 2015 4:32pm |
