![]() | Home > General (L494) > MY16 - Please connect USB. - won't play from usb device |
denny111 Member Since: 07 Dec 2014 Location: Kent Posts: 98 ![]() ![]() |
yes had the same problem
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
I could not get 64gb USB key working but 16gb worked, USB key need to be formatted in FAT32. |
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 ![]() ![]() |
Going to give that a try now. Also I saw in some online documentation that the maps for the sat nav can be updated, poi's added via an sd card, does anyone know where the sd car slot is? Range Rover Sport SVR - Santorini Black
yes you can update the maps and pois
Thanks for the tip, can confirm that maxell 64gb usb stick works with the MY16 sport. Happy days.
Bobajobbob Member Since: 01 Jun 2015 Location: Kent Posts: 137 ![]() ![]() |
Does anyone know what video format is recognised by the system? Does it have to be .avi or will mp4v work? |
I got .mp4 and .mpg working , but only from DVD, tried all types of file types on USB and it doesn't show any. |
Over on BabyRR.com there were so many complaints about USB's not playing that we ran a user survey and found that if you used a memory stick or portable hard drive bigger than 32mbs the car's system took forever to read all the files and often didn't recognise the drive was even plugged in just like above.The car's system was also not happy with many makes of memorystick or portable drive................. maybe time to start a similar thread here with people listing the best makes and capacity/size of memory sticks that will work without a problem. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Has anyone managed to get video stored on a USB stick to work or indeed read the manual? I'm only guessing that it should work given that USB pops up as a source for rear seat media. |
Screenwipe Member Since: 29 May 2015 Location: London Posts: 48 ![]() ![]() |
I've managed to get videos working on USB. After a silly amount of toing and froing with Land Rover and them providing me a painful to read technical document (pm me with an email address if you want a copy) I ended up with the very simple process below.
Anyone got playlists working on a USB stick? Range Rover Sport SVR - Santorini Black
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
Just used this one to play audio mp3 ok.
