Home > General (L494) > MY16 - Please connect USB. - won't play from usb device
Netsters
Got my new,RRS sport autobiography.
Success in playing music I from an iPhone using Bluetooth and cable.
Also played a dvd. If I try to play something from a usb it keeps,saying. Please connect USB' although there is a sub key in place.
Anybody found this as well? Range Rover Sport SVR - Santorini Black
Range Rover Sport Autobiography 2016 Yulong White / black interior - Stealth pack
Ferrari 360 F1 Spider red/cream
Ferrari 348 ts red/cream
BMW M4 Convertible Competion Pack
Post #479669 Fri Nov 13 2015 1:13am
denny111
yes had the same problem
mine will only see a certain usb stick
have tried 4 different usb sticks but will only read 1 stick
suggest you try different makes of sticks till you eind one that it will read
strange l know because the other sticks work in other systems
i now keep this 1 stick just for my rrs
Post #479690 Fri Nov 13 2015 10:20am
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
I could not get 64gb USB key working but 16gb worked, USB key need to be formatted in FAT32.
Post #479692 Fri Nov 13 2015 10:31am
Netsters
Going to give that a try now. Also I saw in some online documentation that the maps for the sat nav can be updated, poi's added via an sd card, does anyone know where the sd car slot is? Range Rover Sport SVR - Santorini Black
Post #479695 Fri Nov 13 2015 10:44am
denny111
yes you can update the maps and pois
You do it with the usb stick which plugs into the usb slot in the centre consul
Post #479700 Fri Nov 13 2015 11:32am
Netsters
usb
Thanks for the tip, can confirm that maxell 64gb usb stick works with the MY16 sport. Happy days.
Anyone know why it is so fussy? Range Rover Sport SVR - Santorini Black
Post #480121 Tue Nov 17 2015 11:32am
Bobajobbob
Does anyone know what video format is recognised by the system? Does it have to be .avi or will mp4v work?
Post #480145 Tue Nov 17 2015 5:00pm
udash
I got .mp4 and .mpg working , but only from DVD, tried all types of file types on USB and it doesn't show any.
Post #480160 Tue Nov 17 2015 7:18pm
Tim in Scotland
Over on BabyRR.com there were so many complaints about USB's not playing that we ran a user survey and found that if you used a memory stick or portable hard drive bigger than 32mbs the car's system took forever to read all the files and often didn't recognise the drive was even plugged in just like above.The car's system was also not happy with many makes of memorystick or portable drive................. maybe time to start a similar thread here with people listing the best makes and capacity/size of memory sticks that will work without a problem. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #480168 Tue Nov 17 2015 8:15pm
Bobajobbob
Has anyone managed to get video stored on a USB stick to work or indeed read the manual? I'm only guessing that it should work given that USB pops up as a source for rear seat media.
Post #480197 Tue Nov 17 2015 9:56pm
Screenwipe
I've managed to get videos working on USB. After a silly amount of toing and froing with Land Rover and them providing me a painful to read technical document (pm me with an email address if you want a copy) I ended up with the very simple process below.
The biggest annoyance is you can only play USB movies in the rear via the rear USB slot, and can only play USB movies in the front via the front slot. Land Rover have confirmed this is working as (very badly) designed.
I'm using a 64GB USB with about 20 movies on it and it works well.
I first get my videos in MP4 format and obviously they need to be DRM free. Then
1. From www.divx.com download divx converter
2. Install it then open it and drag your mp4 file into it.
3. Select output profile “Home Theater”
That's it! You'll find divx very slow and more often than not for me it appears to have hung mid conversion even though it's actually completed its task and the file you want is properly created and sitting in the divx file folder. But once you use it a bit and learn its peculiarities it's pretty easy.
Post #480611 Sat Nov 21 2015 8:45pm
Netsters
Playlists - Anyone got them working?
Anyone got playlists working on a USB stick? Range Rover Sport SVR - Santorini Black
Post #480784 Mon Nov 23 2015 9:13pm
Dave777
Just used this one to play audio mp3 ok.
http://www.ebay.co.uk/itm/SanDisk-64-GB-Ul...1432426787 MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #480796 Tue Nov 24 2015 8:45am
