Home > Technical > Front park aid inactive, no fault shows on the 'secret' menu
Rb1980
I hear ya
Post #478528 Mon Nov 02 2015 3:01pm
Bodsy
Site Sponsor
I'd have the fault codes read before you start trying to trace a wiring fault that may or not be there.
Even though the sensors click, they can still be faulty. If they are, then the fault codes are likely to tell you specifically which one is faulty. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #478538 Mon Nov 02 2015 3:59pm
Rb1980
Good point, might just be easier to put in the garage
Post #478539 Mon Nov 02 2015 4:00pm
PEACHY
Bodsy read my previous Sports fault codes - exactly the same problem as you - needed to replace 2 front sensors - changed all 4 - remember these are battered by the weather day in day out - they don't last forever Thumbs Up 16MY Estoril Blue SVR.............
Post #478561 Mon Nov 02 2015 7:08pm
Rb1980
Cheers I ll get them read and see what's what...
Post #478588 Tue Nov 03 2015 5:48am
Rb1980
update
so just had the fault codes checked. apparently had some 20 codes thrown up. Mechanic reckons caused by jump start/ electrical probs. did have a new alternator recently but sensors fine for a while after that.
anyways, he has cleared the codes and the sensor error message is gone. reckons if it pops back up then either
a software update or no BCM module needed.
anyone know how much for said update? I know RR will try to take the Censored on anything like this!
Post #478922 Thu Nov 05 2015 1:02pm
Bodsy
Site Sponsor
I can update the BCU for you next time I'm down.
Was there any PDC errors at all? Bodsys Brake Bible
See it HERE
Post #479033 Fri Nov 06 2015 8:51pm
Rb1980
No apparently no pdc fault codes showing
Oddly he said a warning light etc should have displayed for some of the historic codes but none
Did.
Will attach his report. What do u think? We did have to have a new alternator fitted a few months ago
Not sure if relevant?
Post #479060 Sat Nov 07 2015 10:11am
Rb1980
Post #479061 Sat Nov 07 2015 10:17am
