![]() | Home > General > Fault code |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
It's not a fault code I have ever seen before. Is that definitely the right code, and does it have a fault description? |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
I have had this code a couple of times when I was in the motor trade, and it alluded to a faulty ABS sensor on each occasion. It also turned out to be exactly that on each occasion. Quite how it is affecting the suspension though I don't know. Unless it is a safety thing built in to stop you still going at road speeds, but that would seem a bit OTT by LR. |
Had a look at this today
Faults cleared, engine started, compressor runs for 10 seconds, then light comes on The only fault code to return is:
Initial diagnostics would indicate a worn compressor or air leak. Upon checking Live Values, the compressor can be checked to ensure it is running, as indicated by the compressor temperature rising. The gallery pressure would not rise much above 4bar of pressure, and is very slow to exhaust any pressure ![]() A quick look under the car, and it has an AMK compressor fitted, but still running Hitachi firmware ![]() Updated the RLM to AMK, but made no difference ![]() Net result, one dead compressor |
