Home > General > Fault code
Ssc11v
Scotland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Fault code
Hi guys
My car is sitting on bump stops will not rise
Suspension fault light on and code c0700 showing
Does anyone know what this is ??? Big Cry
Post #478216 Thu Oct 29 2015 10:38pm
Disco_Mikey
It's not a fault code I have ever seen before. Is that definitely the right code, and does it have a fault description?
Post #478219 Thu Oct 29 2015 11:05pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
I have had this code a couple of times when I was in the motor trade, and it alluded to a faulty ABS sensor on each occasion. It also turned out to be exactly that on each occasion. Quite how it is affecting the suspension though I don't know. Unless it is a safety thing built in to stop you still going at road speeds, but that would seem a bit OTT by LR.
Post #478307 Fri Oct 30 2015 6:32pm
Disco_Mikey
Had a look at this today Thumbs Up
Quote:
SALLSAA138A******
Vehicle scanned on 11-11-2015 15:32
Using IIDTool Pro V3.0 B2696
Auxilary Heater
U1A44-6C (2E) Fuel level
Body Control
B1B70-81 (2C) Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 47348 mi )
U2001-68 (6Cool Reduced system function - Algorithm based failure - event information
( at 51884 mi )
Instrument Pack
U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message
U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message
Suspension
C1A13-64 (6Cool Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
( at 52497 mi )
C1A36-01 (6C) Exhaust valve - General failure information - general electrical failure
( at 51901 mi )
C1131-92 (AF) Air supply - Component failure - performance or incorrect operation
( at 52481 mi )
C1A20-64 (6C) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
( at 52473 mi )
U2000-67 (6C) Motor temperature - Algorithm based failure - signal is incorrect after the event
( at 52497 mi )
Ventilation
B1B75-00 (6Cool Front foot-face mode stepper actuator
( at 47321 mi )
B1B76-00 (6Cool Front left air blend stepper actuator
( at 47321 mi )
B1B77-00 (6Cool Front right air blend stepper actuator
( at 47321 mi )
B1B78-84 (2F) System pressure - Bus signal/message failure - signal is below allowable range
( at 49958 mi )
MMP Land Rover
07951 187204
Mike@mmplandrover.co.uk
Faults cleared, engine started, compressor runs for 10 seconds, then light comes on
The only fault code to return is:
( at 52481 mi )
Initial diagnostics would indicate a worn compressor or air leak.
Upon checking Live Values, the compressor can be checked to ensure it is running, as indicated by the compressor temperature rising. The gallery pressure would not rise much above 4bar of pressure, and is very slow to exhaust any pressure
A quick look under the car, and it has an AMK compressor fitted, but still running Hitachi firmware
Updated the RLM to AMK, but made no difference
Net result, one dead compressor
Post #479502 Wed Nov 11 2015 7:57pm
