Home > Maintenance & Modifications > Misc faults with my TDV8 07 |
redamo Member Since: 13 Oct 2015 Location: Cheshire Posts: 72 |
Just read the stored faults today. Would any of these require further investigation? I've cleared them and will see which ones come back again. BTW, why is the millage reading wrong for the first error? Almost 10mil miles...
Tue Oct 27 2015 2:10pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Check your battery (and alternator).
Tue Oct 27 2015 2:47pm |
Thanks for the reply! How to check if it's up to date? |
Tue Oct 27 2015 3:09pm |
If you haven't already, install the updater from the GAP website (and run it), connect the tool and click "Find Device". Once found, you'll be able to see the current firmware version and it will offer to update to a later one if available. Visiting from DISCO3.CO.UK
Tue Oct 27 2015 3:54pm |
I thought you meant about ECU version. IIDTool was already on latest version before I have read the faults. Should I contact GAP for a potential bug? |
Tue Oct 27 2015 4:03pm |
Yes, I think so. (I've just tried to check, but now I can't find the thread where it was mentioned that it should be fixed. ) Visiting from DISCO3.CO.UK
Tue Oct 27 2015 4:15pm |
Thanks for the replies. After clearing all faults yesterday only the following returned after a short (15-20 min) trip. Guess that I might need to have the battery and alternator checked although everything seems fine (car starting without probs, IIDTool reports 12.4V).
Wed Oct 28 2015 1:32pm |
