Home > Maintenance & Modifications > Misc faults with my TDV8 07
redamo
United Kingdom 2007 Range Rover Sport TDV8 HSE Tonga Green
Just read the stored faults today. Would any of these require further investigation? I've cleared them and will see which ones come back again. BTW, why is the millage reading wrong for the first error? Almost 10mil miles...
Audio Amplifier
B1A96-68 (2C) Bus still active after shutdown request - Algorithm based failure - event information
( at 16777215 km )
Auxilary Heater
U1A44-6C (2E) Fuel level
Body Control
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 200290 km )
Instrument Pack
U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message
U0182-87 (2Cool Lost communication with front lighting control module - Bus signal/message failure - missing a message
U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message
Traffic Message
B1A56-18 (2Cool Antenna circuit - General electrical failure - circuit current below threshold
Ventilation
B1B74-00 (2C) Front foot-defrost mode stepper actuator
( at 200274 km )
B1B75-00 (2C) Front foot-face mode stepper actuator
( at 200274 km )
B1B76-00 (2C) Front left air blend stepper actuator
( at 200274 km )
B1B77-00 (2C) Front right air blend stepper actuator
( at 200274 km )
Post #477961 Tue Oct 27 2015 2:10pm
Lost for Words
Check your battery (and alternator). Thumbs Up
There was an issue with the mileage conversion (kilometres is the native) but IIRC, that should have been sorted out on subsequent firmware versions - have you checked it's up to date? Visiting from DISCO3.CO.UK
Post #477963 Tue Oct 27 2015 2:47pm
redamo
Thanks for the reply! How to check if it's up to date?
Post #477964 Tue Oct 27 2015 3:09pm
Lost for Words
If you haven't already, install the updater from the GAP website (and run it), connect the tool and click "Find Device". Once found, you'll be able to see the current firmware version and it will offer to update to a later one if available. Thumbs Up Visiting from DISCO3.CO.UK
Post #477972 Tue Oct 27 2015 3:54pm
redamo
I thought you meant about ECU version. IIDTool was already on latest version before I have read the faults. Should I contact GAP for a potential bug?
Post #477973 Tue Oct 27 2015 4:03pm
Lost for Words
Yes, I think so. (I've just tried to check, but now I can't find the thread where it was mentioned that it should be fixed. Rolling Eyes ) Thumbs Up Visiting from DISCO3.CO.UK
Post #477974 Tue Oct 27 2015 4:15pm
Paddi
Re: Misc faults with my TDV8 07
redamo wrote:
Body Control
( at 200290 km )
always there on mine - but it is just the battery backup sounder and something else that's not vital on that circuit? Nothing seems to be wrong with them.
Instrument Pack
usually there too - no problems with suspension.
Ventilation
( at 200274 km )
( at 200274 km )
( at 200274 km )
( at 200274 km )
Always there too - and no issues with my HVAC sure I read somewhere that brand new cars leaving the factory have this fault stored so it is just a glitch. Sorry - I seem to have c***ed up the quote thing but you hopefully can see what I mean Embarassed 2008 MY Java Black TDV8 HSE
Post #478072 Wed Oct 28 2015 12:28pm
redamo
Thanks for the replies. After clearing all faults yesterday only the following returned after a short (15-20 min) trip. Guess that I might need to have the battery and alternator checked although everything seems fine (car starting without probs, IIDTool reports 12.4V).
Body Control
B1B70-81 (2C) Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 204200 km )
Ventilation
B1B74-00 (2E) Front foot-defrost mode stepper actuator
( at 204198 km )
B1B75-00 (2F) Front foot-face mode stepper actuator
( at 204198 km )
B1B76-00 (2F) Front left air blend stepper actuator
( at 204198 km )
B1B77-00 (2F) Front right air blend stepper actuator
( at 204198 km )
Post #478075 Wed Oct 28 2015 1:32pm
