Home > General > Emergency Tow Strap |
redamo Member Since: 13 Oct 2015 Location: Cheshire Posts: 72 |
Before I go and pay £60 for this Land Rover Emergency Tow Strap Assembly - STC8919AA, are there better options available? I'm interested only in emergency towing (a few meters only). It might be a silly question, but how is this tow strap attached, is there any screw required to fit on the frame? |
Mon Oct 26 2015 5:01pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Behind the little towing electrics cover, there is a big hook. That can be used for it
Mon Oct 26 2015 5:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
It has a hook each end with a safety catch.
Cheers Col |
Mon Oct 26 2015 5:17pm |
@Pufftmw, thanks, what about in front?
Mon Oct 26 2015 6:35pm |
I really couldn't say one way or the other it's just that I happen to have a L/R one, had it years not even sure where I got it from, probably off e-bay in the day's when I had a P38.
Mon Oct 26 2015 6:47pm |
There's another cover below the front number plate. Never taken it off. |
Mon Oct 26 2015 6:48pm |
Any direct links as there are way too many options? @Col, have you ever got the chance to use the original tow rope from LR? Any feedback? |
Mon Oct 26 2015 7:00pm |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
Where is the front cover ?? |
Mon Oct 26 2015 7:16pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
I have one of these in my RRS:
Mon Oct 26 2015 8:22pm |
I thought that elastic ropes are not indicated.
Mon Oct 26 2015 9:10pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
If in doubt try reading the vehicle handbook and all tow loops will be revealed. 07MY RRS TDV6
Mon Oct 26 2015 10:44pm |
The Halfords' tow rope is actually a strap which has elastic in it to make it contract when not under tension. The elastic plays no part in the towing operation - it's not a kinetic rope. The benefit of the elastic is that it helps prevent the strap dragging on the floor if the vehicles close up slightly.
Tue Oct 27 2015 9:13am |
The Genuine L/R one's are only rated at 3,000KG's so not exactly heavy duty.
Tue Oct 27 2015 4:52pm |
