Home > General > SE v HSE |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4929 |
Thanks very much Tim.
Sat Oct 10 2015 3:57pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Just to be clear, don't expect the compressor to stop as soon as the car is raised - the initial pressure is sourced from the gallery, which then takes a little longer to re-fill.
IIRC the engine icon light should come on briefly as part of the start up checks, like an airbag self check does. If no icon on the self check then suspect that it has been hidden with insulation tape................ and is permanently on, which could be because of EGR or Turbo issues........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Oct 10 2015 4:00pm |
Oh and what does the gong mean at the end of the ignition sequence? Ready to start? |
Sat Oct 10 2015 4:04pm |
Could be any of a number of warnings! From seat belt not done up through a door not fully closed, tail gate not latched to washer bottle low to impending doom in the engine! You can recall the most recent warnings through the column stack IIRC (it is a 5 years since I last drove an RRS1!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Oct 10 2015 4:09pm |
Basically, it's a systems check type thing. You can get various erroneous bongs can on the earlier vehicles (2005 mainly) which got cleared up with later instrument pack software versions. Visiting from DISCO3.CO.UK
Sat Oct 10 2015 4:11pm |
Where are the VIN numbers located on these? |
Sun Oct 11 2015 9:08am |
Bottom left of the windscreen, under the wiper blade. Visiting from DISCO3.CO.UK
Sun Oct 11 2015 9:29am |
Anywhere else? |
Sun Oct 11 2015 10:27am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4960 |
Front Slam Panel under Bonnet and Stamped on Chassis under Front of Drivers Door.
Sun Oct 11 2015 10:50am |
If you should be particularly concerned about it, it's also stored in various ECUs. Visiting from DISCO3.CO.UK
Sun Oct 11 2015 10:55am |
That's guys.
Sun Oct 11 2015 11:07am |
