Home > General > SE v HSE |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
For the buyers guide, the following link will bring it up for you:
Fri Sep 18 2015 2:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4929 |
Thank you very much.
Fri Sep 18 2015 2:51pm |
No, sorry. It's one I downloaded off the internet, and found when I bought my car, and as I was only looking at later models I didn't bother with the earlier ones.
Fri Sep 18 2015 2:57pm |
As it's a 2005 SE (I had one too) then if it has wheels/ tyres bigger than 19" walk away, to fit 20" wheels to a 2005 SE a heavy duty steering rack had to be fitted and this didn't become standard ubtil 2007MY so check that it has had the uprated sterring arck fitted. There are plenty of threads on the forum that tell you how to differentiate if the owner doesn't know.
Thanks very much Tim.
Fri Sep 18 2015 3:19pm |
Yes fogs were standard, I looked in my gallery and in the 2005 spec brochure to see if I had them and have updated the post and added some photos! The Dynamic Pack didn't make a huge difference to the rolling, it wasn't hugely high tech but it allowed you to go up to 20" wheels as it also included the uprated steering rack as well as the hydraulically activated antiroll bars. It was only an option on HSE's from launch but may have been available on SE's later. The S/C had a still better system that could disengage the anti roll bars offroad for additional wheel articualtion.
Fri Sep 18 2015 3:34pm |
Thanks for the info.
Fri Sep 18 2015 3:50pm |
iPhone wasn't invented then! It will work if it has the replacement BT module fitted 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Sep 18 2015 3:52pm |
Any clues as to which ones had the brembo front brakes ? |
Fri Sep 18 2015 3:56pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Dynamic response & Front Brembos came fitted as standard on the TDV8, and the TDV6 HSE from 2007 until 2009. 2014 L405 SDV8 RR Autobiography
Fri Sep 18 2015 5:17pm |
Also the Supercharged V8 had Brembos from day one, if you are not doing big miles and the RRS is a runabout then you could possibly get an early 4.2V8 S/C for similar money to a 2.7SE now and you would get the full on handling pack, 20" wheels as standard, Bluetooth as standard, Hamman Kardon surround sound audio, possibly RSE which was an optional extra, perforated leather sports seats, adaptive cruise and an awful lot more ooooooomph and also a lot less mpg.................. and it would probably have a heap less miles on it too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Sep 18 2015 5:49pm |
Thanks for the info Tim.
Sun Sep 20 2015 5:25pm |
http://www.parkers.co.uk/cars/reviews/fact...tate-2005/ In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Sep 21 2015 8:13am |
Had a look at a 2005 HSE today.
Sat Oct 10 2015 3:42pm |
