Home > Technical > Vibration through car at 60 plus |
vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30 |
Has any one had this problem it drives fine till i reach about 60 then i start getting a vibration through the car ,i carries on right up past 75. Ive had all the wheels balanced and new front tyres fitted still there it feels like a transmission thing, i had a new rear propshaft fitted last year and i don't think it was there before but not sure.Are these cars prone to propshaft/driveshaft problems or is this normal,i feel it's coming from the front .Any ideas anyone |
Sat Sep 26 2015 5:46pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I would check the U/J's on the propshaft as it should no vibrate at any speed. You wont need a propshaft but may need U/J's for them.
Sat Sep 26 2015 5:58pm |
ok will do thanks ,i'll check front prop as rear is new and i've just had two new lower arms fitted .do they suffer with front drive shaft problems as i cv joints ?? |
Sat Sep 26 2015 6:07pm |
I have never had a problem with them and use to have a 2.7.
Sat Sep 26 2015 6:18pm |
Ok thanks Frax |
Sat Sep 26 2015 6:33pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
My 2008 (long gone now) had a rear diff replaced for this problem. |
Sat Sep 26 2015 10:56pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Was it a complete, new rear prop that was fitted? Visiting from DISCO3.CO.UK
Sun Sep 27 2015 7:56am |
Yes the centre bearing had collapsed and the people i use would only fit a complete one and they will only use genuine L/R parts i starting to wonder if the front prop is going, did forget to say it is running 22"stormer wheels and they are genuine ones not patterns.I dont thing its the gearbox as all is working fine in auto and sport mode |
Sun Sep 27 2015 6:17pm |
Also wondered about diffs but cornering makes no difference it the same on sweeping bend and straight lines |
Sun Sep 27 2015 6:21pm |
