Home > General > LR towbar recall? |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
they will check for any wear outside tolerance and rectify if necessary.....book it in
Sun Sep 13 2015 7:34pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
I've just recieved the same letter,,, thanks for reminding me as It had slipped my mind. To be honest i've never used the towbar but I'm going to get it booked in,,,,, anything Foc is worth having!! 2010 RRS, TDV8
Sun Sep 13 2015 7:56pm |
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 |
Yep thanks DrRob, should've done that first. 2016 L494 SDV6 HSE Dynamic Carpathian Grey |
Sun Sep 13 2015 7:57pm |
cootsie Member Since: 31 May 2014 Location: Turriff Posts: 15 |
I had mine checked a couple of weeks ago. It was all checked in Peter Vardy Land Rover Aberdeen and I was told everything is fine and was given a new spec sheet to place in the manual. The removable towbar nose weight has now been changed. I think the nose weight is lowered to 150kg or something like that.
Tue Sep 15 2015 10:35pm |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 |
I've just bought myself a 2010 RRS and in the process of many hours internet searching I stumbled across Topix. Lacking the VIN number of any car I might actually want to buy I entered the VIN of my wife's Disco 3. First thing that pops up was the recall. I didn't pay too much attention, but SWMBO goes into full panic mode and wangled herself an emergency appointment at the local LR dealer. We do use the tow bar every week or so to tow a horse box which obviously transports the most important male in her life. Anyway, it took the dealer an hour to get the tow bar off and then the service wallah eternal ashen faced and tells my wife that she shouldn't even think of towing until the work has been done. He confiscated the detachable tow bar and the car is now spending three days having the cross member replaced! All FOC, obviously. Anyway, do take the recall seriously, but if you don't use the tow bar very often then you will probably be OK. Probably ....... |
Wed Sep 16 2015 6:20am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
This recall has me confused.
Wed Sep 16 2015 9:46am |
I'm far from being an expert, but....
Wed Sep 16 2015 10:05am |
Australian vehicles are rated to tow 3500kg with a nose weight of 350kg. The UK goose neck type tow bars are not legal here. All our bars are a receiver that plugs up into the rear cross member with that stupid key system but the actual tow bar is inserted into the receiver.
Wed Sep 16 2015 10:12am |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
I've got the removable one with a key. I have no key and it is rusted in place. What will they do if I send mine in? Don't want a big daft ugly thing fitted, will they just remove it altogether if asked? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Wed Sep 16 2015 8:48pm |
It didn't occur to us to take the key to the garage, and they never asked for it, so I assume the can sort it without they key. Or, they have a set of master keys. I presume you can opt to go without the heavy duty tow bar, but if your tow bar has been in place as long as it has then I'd reckon there is a decent chance you will have some corrosion of the cross member and need to get it checked. |
Thu Sep 17 2015 5:39am |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 |
I've not had a recall letter yet so am I likely to get one? I cannot remove the tow bar so hope to get a recall so LR can do it for me. |
Fri Sep 18 2015 10:53pm |
Assuming your vehicle is potentially affected then I'm sure you will eventually get one. They get the address details via the DVLA. I also suspect they have staggered the letters so the dealerships can cope. No reason why can't just call the dealership and book in for the check. |
Sat Sep 19 2015 6:40am |
