![]() | Home > General > LR towbar recall? |
they will check for any wear outside tolerance and rectify if necessary.....book it in |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 ![]() ![]() ![]() |
I've just recieved the same letter,,, thanks for reminding me as It had slipped my mind. To be honest i've never used the towbar but I'm going to get it booked in,,,,, anything Foc is worth having!! 2010 RRS, TDV8
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 ![]() ![]() |
Yep thanks DrRob, should've done that first. |
cootsie Member Since: 31 May 2014 Location: Turriff Posts: 15 ![]() ![]() |
I had mine checked a couple of weeks ago. It was all checked in Peter Vardy Land Rover Aberdeen and I was told everything is fine and was given a new spec sheet to place in the manual. The removable towbar nose weight has now been changed. I think the nose weight is lowered to 150kg or something like that.
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
I've just bought myself a 2010 RRS ![]() ![]() Anyway, do take the recall seriously, but if you don't use the tow bar very often then you will probably be OK. Probably ....... ![]() |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 ![]() ![]() |
This recall has me confused.
I'm far from being an expert, but....
Australian vehicles are rated to tow 3500kg with a nose weight of 350kg. The UK goose neck type tow bars are not legal here. All our bars are a receiver that plugs up into the rear cross member with that stupid key system but the actual tow bar is inserted into the receiver.
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I've got the removable one with a key. I have no key and it is rusted in place. What will they do if I send mine in? Don't want a big daft ugly thing fitted, will they just remove it altogether if asked? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
It didn't occur to us to take the key to the garage, and they never asked for it, so I assume the can sort it without they key. Or, they have a set of master keys. I presume you can opt to go without the heavy duty tow bar, but if your tow bar has been in place as long as it has then I'd reckon there is a decent chance you will have some corrosion of the cross member and need to get it checked. |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
I've not had a recall letter yet so am I likely to get one? I cannot remove the tow bar so hope to get a recall so LR can do it for me. |
Assuming your vehicle is potentially affected then I'm sure you will eventually get one. They get the address details via the DVLA. I also suspect they have staggered the letters so the dealerships can cope. No reason why can't just call the dealership and book in for the check. |
