Home > General > Strongman - moi? |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
You mean the wheel brace that LR provide? Yes, it's a known problem, same as the cheese-jack.
Thu Aug 20 2015 5:26pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Ah - phew (sort of) - thought I'd had too many protein shakes...
Thu Aug 20 2015 5:43pm |
kungfupanda79 Member Since: 19 Oct 2011 Location: Manchester Posts: 72 |
Just had a new set of refurb wheels put on mine this afternoon. Some of the bolts were swollen due to corrosion too plus one of the lockers had cracked down the middle and swollen as well. Got them all off but there were some moments where you had to hold your breath.
Thu Aug 20 2015 5:48pm |
Yep, the standard nuts swell, the lockers break (and are best binned). Visiting from DISCO3.CO.UK
http://www.advancedfactors.co.uk/rrd500510...5929-p.asp Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thu Aug 20 2015 5:50pm |
Bon chance Rodney as Del Boy would say |
Thu Aug 20 2015 6:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Bought a set of these the other day. Good quality not L/R but supplied by Allmakes.
Thu Aug 20 2015 7:43pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I think you should go round with you torque rench again as they should be tightened to 103 lbs not 85 2008 G4 RRSport TDV8 current
Fri Aug 21 2015 6:35am |
