Home > In Car Electronics > DAB radio |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Hi if your fitting a aftermarket DAB ( add on unit ) then YES the centre part of the dash will need removing to access your radio ( satnav) connections. You will need to get to your FM aerial connection for your new DAB ariel and also to connect the unit. Also if your buying the steering wheel connections they are also plugged in here.
Mon Aug 10 2015 5:33am |
