Home > Technical > How's your MAP sensor?
Page 4 of 4 <1234
Robsrr
Australia 2010 Range Rover Sport 3.0 TDV6 SE Siberian Silver
I just cleaned my sensor, had a bit of crud in it but not blocked. When I started the car the Restricted Performance red light came on. I removed the sensor again thinking the connection was not correct the inside wasn't dry from cleaning.
The red Restricted Performance light came on as well as the amber engine system light. I think the sensor did not like being cleaned or I damaged it some how.
Rob
Post #468330 Thu Jul 23 2015 11:32am
Robsrr
Just installed a new MAP sensor and faults have gone.
All good.
Rob
Post #469528 Wed Aug 05 2015 6:11am
michaelsanderson
England 2011 Range Rover Sport SDV6 HSE Fuji White
Will this apply to the SDV6 too?
Post #469644 Wed Aug 05 2015 11:36pm
Robsrr
Michael,
Not sure. I changed mine out because I suspected it was faulty. It had a bit crud in the old one which I guess would not have helped. The MAP sensor is an expensive item if you go via a dealer ( well at least here in Australia). I ended up getting a new one less than a third of the price it would have cost from the local dealer spare parts department.
Rob
Post #469647 Thu Aug 06 2015 2:51am
garrycol
Australia
The trick is to not poke anything in the hole when cleaning. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #469649 Thu Aug 06 2015 5:05am
Stuart
As mine was running badly, I have been meaning to do this. Today, I had a spare moment so had a peek........
Hole was visible, but crud was there.
Washed it off with WD40, taking care to poke nothing in the hole per above; despite temptation.
Bunged it back in and drove home.
Big difference! The top end injector rattle/pinking noise has gone. Much smoother on acceleration. A tad more sprightly. Unfortunately, the black smoke on clogging it mostly remains, but it was a nicer drive after doing it.
Drivetrain clunk at slow speeds now seems more noticeable though. Maybe in my head, but I noticed it....... Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #469734 Thu Aug 06 2015 9:43pm
adameverett
Wow guys thanks a lot, tips on here are awesome Very Happy
I took my MAP sensor out on a 2005 with 83k on the clock. Bottom of the sensor was just encrusted.
Cleaned it up re-installed and now my mpg has gone up from 21.5 to 23mpg. (mrs does a lot of town driving) Don't know if this would be expected or somehow I have fooled my self. either way Thumbs Up
Post #498407 Fri Jun 10 2016 9:24pm
Johnski
Would this not be listed for cleaning on the LR RRS service sheet?
Would a code reader give an error or a indication it needs cleaning does anyone know? Would use IID BT. John
Post #498915 Sat Jun 18 2016 12:34am
Page 4 of 4 <1234
