![]() | Home > Technical > How's your MAP sensor? |
m40cca Member Since: 04 Sep 2014 Location: leeds Posts: 89 ![]() ![]() ![]() |
thanks for that dsl just jumped outside removed mine and its full of gunk mines a 06 89k with egr removed but that was only done last month |
rudadu Member Since: 12 Sep 2014 Location: Dunfermline, Fife Posts: 48 ![]() ![]() |
Thanks for the reply Somerset Bumpkin |
Thanks for replies. Eventually, got round to removing MAP sensor. Found it clean as a whistle ![]() Does anyone have any ideas what could be causing the blue exhaust smoke (only when accelerating hard). I've had my RRS for a couple of months now and loving it but the smoke is annoying ![]() I'm up to some easy investigations but don't have facility or tools to "get stuck in" as it were ![]() Thanks in advance for any hints, tips or help. |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
I want to check mine and clean as necessary and have looked at the disco3 forum but want to be sure I know what I am doing. From what I have read I take the oil filler cap off and then tug at the engine cover to remove it which gives me access to the MAP sensor. Is this correct? |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
Yes that's right give it a good tug |
Just checked mine and it was filthy. Now cleaned and hopefully that might help towards my pretty bad MPG. Great heads up post BTW. Just the sort of thing one joins the Forum for. Thanks.
dotty Member Since: 11 Sep 2014 Location: St Heiler Posts: 52 ![]() ![]() ![]() |
Checked and cleaned mine today. As Nigel52 said 'Great heads up post' Thanks
Jemmountford Member Since: 04 Oct 2014 Location: Warwickshire Posts: 20 ![]() ![]() ![]() |
Folks,
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
When Betsy was getting her remap the guy doing it cleaned mine out, and it was FULL of |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
took mine out and cleaned it (quite filthy with just a tiny hole thru the crud) as Jem said, a bit of hunting on tickover just after startup seeems to have gone now, easy job |
Wee update.. Been keeping an eye exhaust smoke over passed months and seems to have disappeared under hard acceleration ![]() Haven't done anything but have been on M8 a lot in recent weeks/months maybe that helped.. This is a cracking RRS forum guys.. really glad I joined up. Hints and tips and other info very helpful. Cheers. |
Range_Driver Member Since: 12 Aug 2014 Location: Stockholm Posts: 4 ![]() ![]() ![]() |
Hi guys,
Update!
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Heres my Map sensor from todays clean. No problems before, just thought I'd check it anyway. It was a bit groggy but haven't noticed many more MPG's or anything than some people report on.
