![]() | Home > Technical > Hand Brake Light Flashing |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 ![]() ![]() ![]() |
Nope, it's back! I've checked the cable for wearing through, I've checked the connectors and all seems fine.
Battery and alternator voltages OK? Visiting from DISCO3.CO.UK
Yeah, battery at rest is 12.6V and when running is 14.1V according to the maintenance page when you do the "753 hack" on the centre screen - one of the pages there gives battery voltages. Although I did have a battery operated pump on all 4 tyres over the weekend and afterwards the "low battery - start engine" alert showed on the dash. Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
That sounds OK. Though, you'll get a slightly more accurate reading directly from the battery. |
No, I haven't checked the fuse as the EPB "seems" to work properly, with the alarm only coming on occasionally. The switch "seems" fine, as it puts the EPB on or off properly, and when the alarm is flashing, using the switch (either on or off) clears the alarm. I can maybe check the fuse tonight, or over the weekend, and I'll also put a meter on the battery too.
Steviesport Member Since: 15 Jun 2014 Location: North Lanarkshire Posts: 52 ![]() ![]() ![]() |
Park brake malfunction appearing ,light flashing and brake not working would this be connected to the dam hdc fault I'm having issues with ?hdc fault was kindly letting me know there is a park brake fault before this one.ive replaced obvious items ie brake light switch tail gate switch battery alternator .next is car to change !! |
Was the EPB warning apparent before, or only after the new alternator? If the latter, what's it outputting and was it Genuine/OE (Denso) or aftermarket?
Thanks for the reply....denso alternator done a year ago before new engine fitment, hdc fault appeared after service a few months ago along with epb fault never replaced bulbs ...surprised to see hdc fault never come on yesterday as I get it 6 times in 70 miles of travelling usually above 60 mph.stopped pulled on epb and light started flashing then epb malfunction and no brakes. |
When you say "no brakes"...? |
Trying to upload video ?!? Off noise when handbrake is applied...obviously not happening |
Range rover sport epb noise: |
Stop using it now, or you'll end up needing a new module. It needs adjusting as per Bodsy's Brake Bible: http://www.disco3.co.uk/gallery/albums/use...ssPics.pdf |
Whats the noise ill try spotify |
