Home > Technical > Hand Brake Light Flashing
Page 2 of 4 <1234>
Ovey
Fingers crossed! Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Previous: Discovery 3 2.7 TDV6 HSE in Zambezi Silver
Post #452794 Tue Feb 17 2015 9:47am
Ovey
Nope, it's back! I've checked the cable for wearing through, I've checked the connectors and all seems fine.
Starting to get a bit disheartened with the new purchase now, and I've not had it a month yet. Crying or Very sad Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #452875 Wed Feb 18 2015 10:49am
Lost for Words
Battery and alternator voltages OK? Visiting from DISCO3.CO.UK
Post #452877 Wed Feb 18 2015 10:53am
Ovey
Yeah, battery at rest is 12.6V and when running is 14.1V according to the maintenance page when you do the "753 hack" on the centre screen - one of the pages there gives battery voltages. Although I did have a battery operated pump on all 4 tyres over the weekend and afterwards the "low battery - start engine" alert showed on the dash. Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #452878 Wed Feb 18 2015 10:57am
Lost for Words
That sounds OK. Though, you'll get a slightly more accurate reading directly from the battery. Thumbs Up
Have you checked the pink 30A fuse in the Battery Junction Box?
I wouldn't rule the switch out yet either.
Thumbs Up Visiting from DISCO3.CO.UK
Post #452879 Wed Feb 18 2015 11:08am
Ovey
No, I haven't checked the fuse as the EPB "seems" to work properly, with the alarm only coming on occasionally. The switch "seems" fine, as it puts the EPB on or off properly, and when the alarm is flashing, using the switch (either on or off) clears the alarm. I can maybe check the fuse tonight, or over the weekend, and I'll also put a meter on the battery too.
Thanks for the pointers so far! Thumbs Up Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #452883 Wed Feb 18 2015 11:23am
Steviesport
Scotland 2008 Range Rover Sport TDV6 HST Stornoway Grey
Park brake malfunction appearing ,light flashing and brake not working would this be connected to the dam hdc fault I'm having issues with ?hdc fault was kindly letting me know there is a park brake fault before this one.ive replaced obvious items ie brake light switch tail gate switch battery alternator .next is car to change !!
Post #468328 Thu Jul 23 2015 11:07am
Lost for Words
Was the EPB warning apparent before, or only after the new alternator? If the latter, what's it outputting and was it Genuine/OE (Denso) or aftermarket?
Have you checked the brake bulbs? (In practise, this means replaced, with high quality bulbs, to be sure.)
Any other symptoms? Can you give a full sequence of events?
Post #468329 Thu Jul 23 2015 11:28am
Steviesport
Thanks for the reply....denso alternator done a year ago before new engine fitment, hdc fault appeared after service a few months ago along with epb fault never replaced bulbs ...surprised to see hdc fault never come on yesterday as I get it 6 times in 70 miles of travelling usually above 60 mph.stopped pulled on epb and light started flashing then epb malfunction and no brakes.
Post #468332 Thu Jul 23 2015 11:49am
Lost for Words
When you say "no brakes"...? Shocked
I would think a wiring fault is probably likely, but I think your "tea leaves" might need reading. Always worth checking voltages etc. first though, even if they should be OK. Thumbs Up
As you've been travelling at speed when the HDC fault appears, I do also wonder about the possibility of the Steering Angle Sensor being at fault - Did it trigger full lowering etc.? Not sure it would fit in well with the EPB fault though.
Post #468343 Thu Jul 23 2015 3:26pm
Steviesport
Post #468420 Fri Jul 24 2015 11:58am
Steviesport
Trying to upload video ?!? Off noise when handbrake is applied...obviously not happening
Post #468421 Fri Jul 24 2015 11:59am
Steviesport
Range rover sport epb noise:
Post #468423 Fri Jul 24 2015 12:08pm
Lost for Words
Stop using it now, or you'll end up needing a new module. It needs adjusting as per Bodsy's Brake Bible: http://www.disco3.co.uk/gallery/albums/use...ssPics.pdf Thumbs Up Visiting from DISCO3.CO.UK
Post #468429 Fri Jul 24 2015 12:48pm
Steviesport
Whats the noise ill try spotify Rolling with laughter
Post #468491 Fri Jul 24 2015 9:50pm
Page 2 of 4 <1234>
