![]() | Home > Technical > Hand Brake Light Flashing |
Steviesport Member Since: 15 Jun 2014 Location: North Lanarkshire Posts: 52 ![]() ![]() ![]() |
Boot open a pole fitted and this dancing round....
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Module is jammed. Strip and adjusted needed, but will not cure your noise. Diagnostics can sometimes unjam it, but more often than not, it needs to be done manually ![]() |
Jesus Christ ..so replacing module will change my ring tone when applying epb ?since I couldn't get a hold of you mikey cars going in on Monday |
Just another question will this be the likely cause of hdc fault I'm having ? |
You don't need to replace the module. Unless you fancy being relieved of best part of £1k |
Cheers guys let you know how it goes next week I'm expecting bad news as always with this car !! |
I'm open to offers guys px cash I'm desperate try me |
£5k |
Sorry wait a minute. Till I wipe my dinner off the iPad.... Had to think about it for 2 seconds I'd give you that for an inside job haha |
In all seriousness, I sent you a PM if you are interested |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 ![]() ![]() ![]() |
I have exactly the same problem here, I have the squeal and flashing parking brake light on the dash! I also had a message on the LCD saying "parking break problem" or words to that effect...how did you manage to sort it? |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
I get that message every morning. Battery needs a good charge. After driving to Scotland for the weekend it was fine for a week. I get brake fault and the radio and sat Nav go on and off for good 10 seconds. Tried new battery and still the same. Have learned to live with it. |
My message actually reads "Park Brake Fault System not functional".
