![]() | Home > General > damp smell after raining |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Do you have a sunroof? |
Marvik125 Member Since: 02 Jul 2015 Location: West Midlands Posts: 139 ![]() ![]() ![]() |
I doubt he does, but his car might |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Do you have a Spaniel? |
steelmen91 Member Since: 25 Aug 2014 Location: lanarkshire Posts: 15 ![]() ![]() |
I do have a sunroof |
Have you recently passed through Calais?
cheers Paddi
Sorry - it is the black plastic thing at the lower edge of the windscreen and through which the wiper arm spindles protrude. There are clips that hold it tight against the windscreen but if some of these are broken or not pushed fully home then water gets in behind the cover, drips into the air intake for the ventilation system and finds its way to the cabin filter and into the passenger footwell. 2008 MY Java Black TDV8 HSE
apologies for the late response as was away on holiday. thanks for that, think it may be the sunroof as when washing it today i did not get the smell until i did the roof. |
just checked the sunroof drains and water runs out all 4 of them so guess thats not the issue....
hi everyone,
CapitolP Member Since: 27 Jun 2014 Location: Essex Posts: 3 ![]() ![]() ![]() |
Hi
I also had this recently- took in to my Indy and they cleaned out both sunroof drain pipes- about £35, fixed. |
thanks for the response guys.
It could also be the sunroof seal. |
