Home > General > damp smell after raining
steelmen91
Scotland
can anyone help me out. After it has been raining heavy or i have washed my car I get a damp/musty smell in the care even before I switch on the engine. I have read comments about the A/C causing this type of smell but I smell it as soon as i open the door.
I have checked all the carpets and there is no damp patches so I am at a loss as to where the smell may be coming from, so appreciate any pointers you guys can give
cheers
Peter
Post #466999 Wed Jul 08 2015 9:02pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Do you have a sunroof?
Post #467008 Wed Jul 08 2015 10:48pm
Marvik125
I doubt he does, but his car might Laughing Rolling with laughter
Post #467014 Wed Jul 08 2015 11:15pm
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Do you have a Spaniel? Laughing
Post #467051 Thu Jul 09 2015 2:11pm
steelmen91
Scotland
I do have a sunroof
Post #467059 Thu Jul 09 2015 3:23pm
Paddi
Have you recently passed through Calais?
After you have checked for the absence of migrants and spaniels maybe double check the carpets; they may be dry on the surface but there are thick layers of felt underneath that can hold large volumes of water. Known sources of leaks are the sunroof drains, front A pillar clips and a poorly fitted plenum chamber cover.
If you are sure the carpets and felt are dry try using an air conditioning 'bomb' to sterilise the air con plumbing.
http://www.halfords.com/motoring-travel/en...on-cleaner 2008 MY Java Black TDV8 HSE
Post #467062 Thu Jul 09 2015 4:01pm
steelmen91
Scotland
cheers Paddi
as I know nothing about cars, what is the plenum chamber cover?
Post #467066 Thu Jul 09 2015 6:09pm
Paddi
Sorry - it is the black plastic thing at the lower edge of the windscreen and through which the wiper arm spindles protrude. There are clips that hold it tight against the windscreen but if some of these are broken or not pushed fully home then water gets in behind the cover, drips into the air intake for the ventilation system and finds its way to the cabin filter and into the passenger footwell. 2008 MY Java Black TDV8 HSE
Post #467144 Fri Jul 10 2015 12:33pm
steelmen91
Scotland
apologies for the late response as was away on holiday. thanks for that, think it may be the sunroof as when washing it today i did not get the smell until i did the roof.
Post #467693 Thu Jul 16 2015 4:32pm
steelmen91
Scotland
just checked the sunroof drains and water runs out all 4 of them so guess thats not the issue....
need to get a hose on it and work my way up
Post #467702 Thu Jul 16 2015 5:03pm
steelmen91
Scotland
hi everyone,
i thought that this smell had went for good as last year it just disappeared, but it has reappeared again. I think it may be a problem that i saw in another thread where the sunroof may be the problem, as I tried the drains from the sun roof and they were fine. Would anyone be able to tell me if the problem was the sunroof would it be covered under Land Rover's extended warranty?
thanks in advance
Post #499466 Sat Jun 25 2016 11:53am
CapitolP
England 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Hi
I once had the same issue on my last RR, also was getting water on the lower door seal. Turned out to the windscreen, had been replaced previously, and not correctly sealed. Got it replaced in the end.
Post #499750 Tue Jun 28 2016 11:28am
Bladeboy
I also had this recently- took in to my Indy and they cleaned out both sunroof drain pipes- about £35, fixed.
Post #499758 Tue Jun 28 2016 1:57pm
steelmen91
Scotland
thanks for the response guys.
i had previously put the hose on it working up the car and it does seem to be coming from the sunroof. I opened the sunroof and poured water down all the drain holes and it seemed to flow through without a problem. Do you think although the water runs through that the problem could still be the drains?
I also cant find any signs of damp in the car, but the damp smell is pretty strong when you jump in the car after a heavy shower
Post #499789 Tue Jun 28 2016 7:47pm
Bladeboy
It could also be the sunroof seal.
Post #499790 Tue Jun 28 2016 7:51pm
